#323 | |
Drives: Subaru BRZ 2013 Dark Gray
http://www.edelblog.com/wp-content/u...07/fender1.jpg |
#324 | |
The IC core
Agreed. At first glance of the pictures I'm disappointed, but everything else looks "On Point" and modern colloquialism puts it. It seems comparing Cosworth, Harrop and Edelbrock, one has quad cooling, the next 2 W2A units and Edelbrock the one unit. I hoped that the single unit was about the same total size as the Harrop's two units, but it doesn't appear so. Ah well, as above, we will see what comes out in the wash. But, I do so want something with enough headroom to be able to justify built engine in several years. Cheers, Budo |
#325 | |
| The Following User Says Thank You to wparsons For This Useful Post: | RobertPaulson (08-14-2015) |
#326 | |
I have no doubt the Edelbrock will have a far more sustainable output. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#327 |
Oh, and....
| The Following 9 Users Say Thank You to CSG Mike For This Useful Post: | bedabi (08-14-2015), civicdrivr (08-11-2015), CxG (08-11-2015), FLIPs_FR-S (08-11-2015), funwheeldrive (08-11-2015), G-Man (08-12-2015), Porcupint (08-12-2015), SuperDave (08-25-2015), tahdizzle (08-11-2015) |
#328 |
Drives: '13 SSM BRZ Limited 6MT
#329 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#330 | |
That Guy
Drives: 2013 asphalt FRS MT
#331 |
#332 |
#333 |
Right, that's a whole new intake.
You can see the intake and tube in this picture a lot better http://www.edelbrock.com/automotive/...ers/fa20.shtml Looks like the same air "input" location (without the stock snorkel) to a larger filter? Which is then straight into the intake |
#334 |
#335 | |
Drives: Evo 9
Based on images I have seen online, both Harrop and Cosworth are using Bosch pumps. Lastly, fin density on both the charge-air-cooler and front heat-exchanger is key. It may be too early to find this info, but Edelbrock usually posts the performance specs of each in BTU's/hr. Basically, you can't tell how something will perform based on size alone. |
#336 | |
Drives: toyota mr2/ Toyota GT86
agree about the BTU statement, I'd be surprised if they release that information thou I remember the cosworth statement was the coolers were good for about 35Kw of heat rejection which they equated to about 400Bhp also the cosworth hoses are 0.75" not 0.625" and have you got any details about this 8 GPM pump? I'm always on the lookout for better pumps.. |
| Tags |
| boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger |
| Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 07:09 PM |
| X-Force 3" Exhaust | mwjcyber | Engine, Exhaust, Transmission | 19 | 03-13-2017 03:55 PM |
| The force is strong with this one (2015 STi) | blackhawkdown | FR-S / BRZ vs.... | 39 | 08-01-2014 02:26 AM |
| X force or Invidia N1 | JakeG | AUSTRALIA | 8 | 01-18-2014 06:16 AM |
| G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 03:24 PM |
