go_a_way1
Old 07-27-2015, 03:47 PM   #183
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by SkiRideDrive View Post
Go away troll. If you have something to provide to the discussion please do so.
Sorry to hurt your feelings. Was merely agreeing with Cross about the "comparison". You're doing a fine job and keep up the great work.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
SkiRideDrive (07-27-2015)
Old 07-27-2015, 03:47 PM   #184
Cross
It's the Mad Cow
Cross's Avatar
Probably... but the Jackson was my number one choice due to reviews and carb until edelbrock came along. So that's where I put my effort in comparing.
I am not really worried about Carb Cert's as we don't have them here. I just want to see performance wise for a Twin Screw setup. I am looking into it now but it will probably be a lot easier once an outside source can show independent dyno results.
Old 07-27-2015, 03:50 PM   #185
Freeman
Freeman's Avatar
Makes sense. But why not compare it to the carb legal tunes of the Innovate/Sprintex kit. Granted it's not a good comparison as this is a large SC vs a small SC, but it's in the right ball park due to being similar types of SC.
Old 07-27-2015, 03:50 PM   #186
Maximania
Drives: ~
Originally Posted by Freeman View Post
What?! Compare a twin screw to a twin screw?! That makes too much sense for the Internet.
Isn't this an Eaton unit, also known as Roots type? Not a twinscrew. Though they are both PD
Maximania is offline   Reply With Quote
The Following User Says Thank You to Maximania For This Useful Post:
Freeman (07-27-2015)
Old 07-27-2015, 03:52 PM   #187
Freeman
Freeman's Avatar
True. So I guess we compare this to cosworth then?
Old 07-27-2015, 03:55 PM   #188
Cross
It's the Mad Cow
Cross's Avatar
The designs used by Eaton now (And Magnuson) claim to be comparable to Twin Screw's and technically they are twin blade setups.
Are they different yes, the Twin Screw is suppose to be far more efficient yet the Root's is the common blower used by OEM's. Again they both are PD Setups but to me Sprintex was not one I put next to say Kenny Bell.
Old 07-27-2015, 04:02 PM   #189
Maximania
Drives: ~
yup. Not particularly impressed with Cosworth numbers so far. Only ones to put up numbers for Cosworth as far I know is RallySport. Torque down low for a Roots type is pretty bad. It jumps and spikes early on, and only builds appreciable torque ~4000 rpms. The E-force seems to build it just a little bit earlier and stays more linear
Old 07-27-2015, 04:07 PM   #190
Freeman
Freeman's Avatar
I've been following cosworth and edlebrock and Harrop. I haven't seen very much coverage on 3rd party dynos, but I hope that changes. I'd love to get a PD blower to replace my centrifugal unit. low end torque is what I'm mostly interested in.
Old 07-27-2015, 04:26 PM   #191
Perhaps I can shed more light on this.
The Edlebrock unit will have more torque down low, while the Jackson Racing supercharger will have more power up top. Different powerbands for different purposes. Ultimately, the powerbands of the units both have to work around the same restriction: CA 91 octane. This restriction works well in the favor of consumers in that it reveals how the two superchargers have strengths in different areas. The short version is that the TVS900 used in the Edlebrock system can start flowing more air sooner (at lower RPM) than the Rotrex in the Jackson Racing system, but ultimately is not as efficient in the upper half of the RPM range. Remember, both kits are working with a highly limiting CA 91, so the only way to really make more power, is to be more efficient.
I 100% expect the Edlebrock to be CARB before release, similar to Jackson Racing; both companies have a strong history of complete products that work out of the box without any fiddling, missing parts, "hacks", or complications.
Edlebrock pricing is still TBD, but I expect pricing to match the relative complexity of the system.
Per the bosses at CSG, CSG will be an Edlebrock dealer, and will have kits available at launch time.
The Harrop system will likely not be a contender in North America due to exchange rates, tariffs, etc.
The Following 13 Users Say Thank You to CSG Mike For This Useful Post:
10Stars (07-29-2015), BigFatFlip (07-27-2015), Dream20b (07-27-2015), drewbot (07-27-2015), Freeman (07-27-2015), funwheeldrive (07-28-2015), HachiEnam (08-21-2015), JoeBoxer (07-28-2015), Lonewolf (07-27-2015), RobertPaulson (08-14-2015), Sleepless (07-27-2015), Toyota86.ir (02-11-2016), whataboutbob (07-31-2015)
Old 07-27-2015, 04:31 PM   #192
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
When you say the price will reflect the complexity of the system, are you assuming it is more complex than say jackson racing setup, and thus will carry a higher pricetag?
SkiRideDrive is offline   Reply With Quote
Old 07-27-2015, 04:38 PM   #193
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I thought they announced this was going to use a TVS 1320 unit?
Old 07-27-2015, 04:43 PM   #194
Freeman
Freeman's Avatar
Thanks Mike!
Do you have any experience with Edlebrock systems? I've seen it referred to as "it'll break" in certain circles, and it made me a little wary. Admittedly I haven't done any looking into reliability of their other offerings yet, mainly because I know it'll be a tooth and nail fight with the wife to change over to a different type of boost. And I haven't even decided what I would go with yet
Old 07-27-2015, 04:44 PM   #195
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
[/IMG]
ohmai18 is offline   Reply With Quote
The Following User Says Thank You to ohmai18 For This Useful Post:
hmong337 (07-28-2015)
Old 07-27-2015, 11:55 PM   #196
sato
sato's Avatar
Drives: Dodge Patitas
That torque curve just doesn't want to die... Granted, they only took it to approximately 7250rpm, but looks good to me!
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 07:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 03:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 02:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 06:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 03:24 PM
