#281 |
I've watched that video way too many times. Love the little engine that could sound.
#282 |
Y u do dis?
Looks like I need a short intake for my 210, for Teh Noizez
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#283 | |
Drives: '14 981CS, '99 NB1
I've done this many many times on K-series motors and we use a standard adapter plate (made by p2r and other companies) to adapt larger Honda TB's in the 78-80mm range. This was the secret for us to unlocking the higher end of the flow range for blowers. |
#284 | |
#285 | |
Drives: 2014 FT86
Regardless--it looks like there's 4-5 of you chasing 400whp or better on stock blocks. This should be good
#286 |
Yes - it might work easier. The electronics are all the same though - as after some minor fitment modifications, the Tundra TB worked fine with OEM Honda ECU logic (tuned of course). It's really down to fitment and cost. The 90mm Tundra TB (at the time) was $1000.... not exactly awesome. A 78MM Acura MDX TB is $195. So there's some investigation / experimentation to be done there.
#287 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The TB is a tough question. We tried doing something similar on the MX5 where we make a large intake plenum, but the problem currently is that this style of TB (identical as the BRZ almost) has integrated hall effect TPS sensors it looks like. Then there's the polarity. If any of those are out of whack the ECU will go into a failsafe mode. We have something in the works but it is just damn near impossible to do any more R&D work right now as we're in the busy season. We're also investigating whether this HP vs Torque ratio has some belt slip in play. Wouldn't be out of the question. |
| The Following 3 Users Say Thank You to Xero-Limit For This Useful Post: |
#288 | |
I've flowed 400+ hp through stock header / exhaust on a 2011 Civic Si (K20) with a Rotrex blower on E85. I went to a high end header / 3" exhaust on the same setup and the gains were basically identical to what they would make on a NA K20, if not slightly less. Similarly, I've spoken at length about the effects of exhaust work on PD blowers with the owner of Hondata, who has an extensive amount of experience there. He said that on a car making roughly 300hp on stock exhaust, they only saw an 8whp gain when swapping to a full 3". I'm not saying this to dissuade you - there will be a difference. I'm just trying to add to the discussion in a way that targets the best $/hp here based on my experience. Now I'm really curious about TB compatibility, as the Honda K/J series TB's appear to have the exact same wiring harness plug on them as the OEM 86 TB. I wouldn't be surprised if the same company (Keihin) makes most of the TB's used by Honda/Subaru/Toyota - and they're all compatible given physical fitment considerations. Last edited by johan; 05-26-2015 at 05:40 PM. |
| The Following User Says Thank You to johan For This Useful Post: | bfrank1972 (05-26-2015) |
#289 |
Drives: 2014 FT86
Hitachi? Nippon Denso?
#290 |
Denso is definitely a possibility. Looks like they are largely similar to the Keihin ones (same motor / actuator housing / plug). They could just be compatible or even possibly a re-brand / sub-contract build in some cases.
Hitachi looks to be what Nissan uses. I need to dig through my old Honda parts and see if I still have a K20 TB sitting around, this can't be hard to figure out. |
| The Following 2 Users Say Thank You to johan For This Useful Post: | bfrank1972 (05-26-2015), Calum (05-27-2015) |
#291 |
Drives: 2013 FR-S Argento
Great info here, thanks guys - if I make the jump to FI this year the 335 is top of my list. Earlier in this thread there's some initial dynos - they show a huge low/midrange with some significant falloff at the top. Originally some attributed this as a characteristic of the blower, but I'm starting to wonder if the TB is a restriction with the 80mm pulley in the upper rev band (thus the falloff)? With a larger TB we might see a flatter torque curve across the rev band even with just the 80mm pulley...
#292 | |
#293 |
Drives: subaru
Whats possible on 93/94 octane? I am soon purchasing a SC and stuck between kraftwerks c38 or this 335 kit. My goals are around 300whp/250tq on pump while running a stock motor.
Not sure if a dyno was done running pump gas but i would be interested in seeing the results. No access to E85 here |
#294 | ||
Y u do dis?
From what I gather, running the 210 is safer off of E85, unless you want to run water/meth injection, which can be a small headache, especially if you run out. new/Built motor may be in your future as well if you run the 335 on pump gas
Dat Hot Lava Doe
| The Following User Says Thank You to Dream20b For This Useful Post: | BRZ'13 (05-30-2015) |
| Tags |
| 500whp or bust, sprintex, sprintex 335 |
| The new sprintex 335 supercharger | jet86 | Forced Induction | 39 | 11-01-2014 11:27 AM |
| Innovate/sprintex SC | rudysaliby | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-28-2014 03:14 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 24 | 04-04-2014 02:38 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 5 | 03-05-2014 07:26 AM |
| TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing | TyperRspec789 | Forced Induction | 63 | 12-31-2013 07:39 PM |
