#127 | |
Drives: Raven FR-S
How are you getting 25 mpg with the bigger blower?? I can barely get 20 mpg on my 210 with the current delicious tune
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#128 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
#129 | |
Drives: Raven FR-S
10-4. I may be giving you a call soon.
#130 |
Drives: 2017 Camaro 1SS
#131 |
Drives: GT 86
Jeeeezzz don't know what you guys are doing but I get as low as 6.4 Lt / 100 km on a long run and average about 8.5
I googled the conversion to US gallons and 6.5 works out at 36 mpg and 8.5 is still over 27 mpg
#132 |
That Guy
Drives: 2013 asphalt FRS MT
#133 |
Drives: 2013 Pearl White FRS
I have to wonder why all the numbers you have on your tests are so different than what I saw at the 3 different tuners that I had look at my car for the last 18 months with a 335.
For example, we saw about 16-17 pounds of boost with a 72mm pulley... Nothing about your kit/numbers seems to be close to what my kit actually did. |
#134 | |
Drives: Scion FR-S
| The Following User Says Thank You to djliquidsteele For This Useful Post: | Xero-Limit (02-15-2015) |
#135 |
Junior
Drives: a car
You might be over compensating on the fuel injection in the higher RPMs to stave off knock. Thats the only thing I can think of.
#136 |
Drives: GT 86
#137 |
Drives: Supercharged GT86
Any issues in the 3k miles you've covered so far?
#138 | |
Just burning up what's left of the snow tires. Waiting for the thaw so we can put back on the coilovers and 18x9.5 rpf1s and smoke some real rubber and break some axles. We'll run this in SM auto-x at the very least this season. Got what I think may be a lousy tank of gas the last time (noticed it was going a bit slower). Took out 2 degrees of timing and it was all back to normal.
#139 |
Be interesting to see how far you get before axles/drive shafts get broken!
What's been/going to be done about additional cooling? I assume intake temps are much higher than that of the 210 kit? I'm getting around 29mpg (UK) average on my 210 kit, good to see the 335 isn't too much different unless you're thrashing it |
#140 |
Drives: GT 86
Intake temps should be lower with the 335 .
| The Following User Says Thank You to sam69 For This Useful Post: | Chad86 (02-15-2015) |
| Tags |
| 500whp or bust, sprintex, sprintex 335 |
| The new sprintex 335 supercharger | jet86 | Forced Induction | 39 | 11-01-2014 11:27 AM |
| Innovate/sprintex SC | rudysaliby | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-28-2014 03:14 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 24 | 04-04-2014 02:38 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 5 | 03-05-2014 07:26 AM |
| TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing | TyperRspec789 | Forced Induction | 63 | 12-31-2013 07:39 PM |
