Old 12-09-2014, 06:53 PM   #15
cliff p.
Drives: '15 BRZ series.Blue
Just tried flashing with the file in the 2012 directory, no other files in that folder. When it flashes, it shows in the log that its using the correct definition file. When finished it still returns the checksum routine start refused. =|
cliff p. is offline   Reply With Quote
Old 12-09-2014, 06:55 PM   #16
cliff p.
One thing I did notice that is not in the D00C definition that exists in all others is the checksum line (line 39 indicating subarudbw). I'm wondering if I should manually write this value to the definition and retry...
Old 12-09-2014, 06:56 PM   #17
steve99
Originally Posted by cliff p. View Post
This is the source for the definition file I used. Specifically: https://raw.githubusercontent.com/TD...Z/ZA1JD00C.xml
Ok found the problem.
their is an error in the definition file for your rom.
The Checksum routine method is not specified
<flashmethod>subarubrz</flashmethod>
<memmodel>SH72531</memmodel>
<checksummodule>subarudbw</checksummodule>
add the line in bold to your definition after the "memmodel" line and it should be fine or copy it from say a D00G def, just that one line though.
the stock rom has the correct checksum so you were able to flash it
however the oft rom must have needed the checksum corrected but ecuflash never checked due the missing line in the definition for your rom. you must be one of the first guys flashing a D00C rom.
I will contact @Td-d so he can correct it on github
steve
The Following 2 Users Say Thank You to steve99 For This Useful Post:
cliff p. (12-09-2014), Tor (03-12-2018)
Old 12-09-2014, 07:01 PM   #18
cliff p.
Thanks lol I'm going to try again!
The Following User Says Thank You to cliff p. For This Useful Post:
steve99 (12-09-2014)
Old 12-09-2014, 07:17 PM   #19
cliff p.
That did the trick
Old 12-10-2014, 11:57 AM   #20
cliff p.
steve
I submitted a commit in github (I use github for many other things )
He will see the review request and can merge my fork as a commit into the xml.
steve99 (12-10-2014)
Old 12-11-2014, 12:30 PM   #21
mid_life_crisis
Drives: FR-S 10 #103 AT
I think the answer to this question is in here somewhere, but I am more than a little paranoid about screwing up my car so here goes.
On the OFT site there is a link for Romraider definitions for use with the V1.xx tunes. It comes with a warning not to use them with V2.xx tunes.
There is no link for definitions to use with the V2.xx tunes.
Can someone please explain where to find these in clear, precise, un-screw-up-able terms?
Old 12-11-2014, 12:45 PM   #22
steve99
the V2 tune definitions are in the zipped file when you download the V2.062 tunes
last link on this page
http://openflashtablet.com/Automotiv...ads/index.html
mid_life_crisis (12-11-2014)
Old 12-11-2014, 02:04 PM   #23
mid_life_crisis
They actually included everything you need to flash and safely edit the tune?
What's up with that? Pretty sneaky being all efficient and stuff.
Old 10-22-2015, 08:41 PM   #24
piaoyi
piaoyi's Avatar
Drives: Sakura Miku
Does anyone know where I can get the definition file for ZA1JD00C? been looking everywhere for it but no luck
Niknej-jenkiN
piaoyi is offline   Reply With Quote
Old 10-22-2015, 08:42 PM   #25
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
The OFT website. They include them with the maps.
jawn is offline   Reply With Quote
Old 03-12-2018, 01:07 PM   #26
Kimviklund
Drives: 2017 Brz
I just edited my v.3 OFT stg1 tune (ZA1K00G)in romraider with a RR_ZA1K00G definition file and it is working, am I just lucky I didnt brick my ecu?
Kimviklund is offline   Reply With Quote
Old 03-12-2018, 04:24 PM   #27
elBarto
elBarto's Avatar
Drives: Toyota GT86
A K00G is really a K00G, there isn't anything edited inside the rom.
The danger is when you take (as example) an OFT 700G rom with a RomRaider def, because the OFT 700G rom is actually an A01G rom edited to 700G and it has modified code inside the rom to have Launch Control and Flat Foot Shifting.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 12:24 PM
