Old 06-09-2012, 11:34 PM   #29
CzRceCar
Drives: 2013 Scion FRS
I have worked for Discount Tire Co. for 4 years now. If you purchased a new set of wheels there are rebuild kits for our FRS/BRZ's sensors. At any DTC we can swap the sensors for much less than a dealer and programming is not necessary from what i have found so far. Like all toyota's,Subaru's unless you are replacing a damaged sensor with a replacement Schrader or Dill sensor they Auto relearn to the vehicle.
So there should be no need for going to any dealer and over paying for this. I had my FRS on a lift today checking clearance to order wheel's and tires and was speaking with our dept on just such a matter.
CzRceCar is offline   Reply With Quote
Old 06-09-2012, 11:35 PM   #30
CzRceCar
For example during rotations there is no need to relearn the sensors to the new positions on the vehicle. Just the same when installing new wheels and swaping sensors over there is no need to relearn.
Hope this helps
Old 06-10-2012, 10:53 AM   #31
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Programming was mentioned for those who want two sets of wheels. Having two sets of sensors will require programming t least once. Hopefully the system will hold two sets of sensors.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-10-2012, 11:19 AM   #32
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Thanks for the detailed write up! how about some result pics in the day and night, is it 100% perfectly fixed?
chulooz is offline   Reply With Quote
Old 06-10-2012, 02:15 PM   #33
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
I wonder if you remove the needles like you do in the TC, have you been able to remove the Ac panel?
Juanito08 is offline   Reply With Quote
Old 06-11-2012, 01:28 AM   #34
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Actually, at night there is a BARELY BARELY BARELY glow that escapes around the tape that I inserted. I can only notice it if I stick my nose right in there and focus... so essentially it is a 99% perfect job but the tiny amount of light that escapes isn't enough to be noticed.
Old 06-11-2012, 01:31 AM   #35
chulooz
Registered you sir
chulooz's Avatar
So you think it goes around the tape? could a larger piece fir without interference and was the tape totally stuck onto the bulb side or only wedged in?
Old 06-11-2012, 01:35 AM   #36
ScottyP3821
ScottyP3821's Avatar
Drives: 2008 Ranger 4cyl 5speed 2/3drop Blk
+100000000 for shade tree reference I loved that show as a kid.
2008 Ford Ranger BLK Lowered 4cy 5 speed 40 series Flowmaster Daily Driver. Fun little work truck but looking forward to my FR-S when I finish my degree June 2013.
ScottyP3821 is offline   Reply With Quote
Old 06-11-2012, 01:38 AM   #37
DarrenDriven
NW Region Moderator
Yeah, I didn't really make my tape perfect, but when I say it barely shines through I am talking that it is SO dim that it is almost completely impossible to see it, even in total darkness. The tape was only wedged into the bulb cavity. I'm sure that someone could think of something better to push in there that might fill the cavity a little more perfectly.
Old 06-13-2012, 01:44 AM   #38
DarrenDriven
NW Region Moderator
Here is a photo of the cluster after blocking the light.
Old 06-13-2012, 02:37 AM   #39
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Can you reach the LEDs from the back? Or would that require further disassembly? I feel like pulling the light could be a viable solution as well...
- The Ancient BRZ Sacrament
by Zaku
Old 06-13-2012, 07:46 AM   #40
DarrenDriven
NW Region Moderator
Already asked and answered...
Originally Posted by DarrenDriven View Post
I tried to separate the gauge cluster to remove the light, but to do that you need to pull all the needles, pull the dial face off and access the screws underneath it. I gently tugged on one needle to see if it would come off easily and it didn't. I feared that I would damage the cluster by removing the needles, so I went this route instead.
Old 06-14-2012, 08:52 PM   #41
CzRceCar
The Programming is all done with the sensors themselves. You clone the sensors coming off the vehicle. Basically if done correctly say you're going out for a weekend Auto-x. As long as you mark your tires with chalk as to which positions they came off you should be able to unbolt one set and bolt on the track set and then bolt on the daily set on the drive home.
tomorrow i was going to check into this issue specifically at work as i am ordering a new set of wheels and tires myself. I will repost Tomorrow evening with a more clear answer.
Old 06-15-2012, 11:27 AM   #42
niceassfd
Drives: 2013 scion Fr-s
thanks for the write up
Thanks for the write it, it takes a lot to do that.
niceassfd is offline   Reply With Quote
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
Subaru TPMS Nonsense Grimlock BRZ First-Gen (2012+) -- General Topics 67 10-07-2013 03:15 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
