#309 |
Drives: 2013 SWP BRZ
| The Following 4 Users Say Thank You to xxscaxx For This Useful Post: |
#310 | |
Drives: 13 Brz Jrsc
dont use glass cleaner on lexan or any other plastics. if it has ammonia in it. it will cause tiny little cracks every where
#311 |
Drift Specialist
Drives: 180SX,GT86
![]() duplicolor metalcast and rustoleum crystal clear
#312 |
Just wanted to add another photo of my setup. Metalcast red /spramax 2k Urethane Clear coat.
![]() Clean Culture OC Meet by xxscaxx, on Flickr |
#313 |
Has anyone tried buffing after wetsanding before the clear goes on? The wetsanding will still dull out the finish a bit, and I figured it would look better if you do a machine polish step after wetsanding before the clear goes on, then wetsanding/buffing the clear.
Also, how long are you all typically waiting between coats? I'm thinking 2 hours should be good. |
#314 |
#315 |
I wetsanded between the red if I needed it, but i think i only did on the second to last coat. Then applied my final coat of red, then applied the clear. Did not wetsand the clear, only two small spots that I accidentally ran the clear.
#316 |
The Comedian
Drives: SWP BRZ Limited
That looks great! So clear and very OEM
#317 |
Great, thanks! How many coats of clear did you use? Looks freaking gorgeous. Could never tell it wasn't OEM
#318 | |
I used like 3-4. The Spraymax only offers 24 hours of usage after opening, so I applied a crapload because it was going to go to waste haha. |
#319 |
Drives: 2013 FR-S, 2012 MCS
How's the success rate on wrapping these? I'm going to get it done professionally but even so that fin thing looks truly difficult to get perfect.
#320 |
I tried it and it didn't work out. But I've never wrapped anything in vinyl before and I'm not really good at detail work anyway, but I did manage to do a pretty decent job on my dash trim. The fin part wasn't really a problem.
#321 |
Here's what I used:
Duplicolor Metalcast (2 cans used) 4 medium coats (45-1 hr in between) light wetsand (2000 grit) 1 medium/light coat Do not be alarmed when your lights look like this after the red coats... ![]() Rustoleum 2x Clear (2 cans used) 4 medium coats (45-1 hr in between) light wetsand 2000 grit and polish/buff 1 medium coat light wetsand (2000 grit) and machine polish w/ abrasive polish After the final coat of Clear: ![]() I'm pretty happy with the final result - still a little bit of orange peel in the paint/clear which you really can't see unless you look at the lens surface from the side, and may end up doing a few more coats of clear at a later time, followed by some more and heavier wetsanding, but overall I think they look good, but most importantly, better than stock. ![]() ![]() ![]() reflection in the tail lights are just clouds: ![]() ![]()
#322 | |
Snow Don't Hurt!
| The Following User Says Thank You to chanomatik For This Useful Post: | xxscaxx (09-13-2013) |
| Are you going to smoke out your tail lights? | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-06-2012 10:02 AM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 02:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 03:30 PM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 07:20 PM |
