#29 | |
Drives: Subaru BRZ, Nissan 240sx
#30 |
Go Tomei UEL and call it good. Cheap and good gains (more power throughout compared to Tomei's EL)
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | Mr.Impreza (10-15-2015) |
#31 |
Drives: 2014 BRZ Limited
I just want something to drown out all the ticking and general bs sounds coming from the car at stock.
#32 |
SLO NO MO
#33 | |
Drives: 2013 FRS
![]() http://www.ft86club.com/forums/showp...58&postcount=1 |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | DAEMANO (11-26-2014) |
#34 |
Drives: Toyota 86 GTS
Don't forget long tube EL which fixes both torque dip and top end afaik
#35 |
This is a UEL header.
I'm running the 2.062 UEL 91 Oct stage 2 tune on my AR header, and I like the way it runs with this tune, better than the EL tune. Looking closely at my header, a "TOP SPEED PRO-1 Performance Header Straight Flex Pipe", I've just noticed that the 2 front primaries are shorter than the rear primaries, so it is a UEL header! Attached is a pic of the header.
I will be Dyno testing 3-5 tunes on Dec 5th with my controversial Anti-Reversion header. I will be testing the unaltered version of the same header the following week and we'll see which headers and which tunes work the best. Last edited by KoolBRZ; 11-27-2014 at 02:31 AM. Reason: clarity |
#36 | |
Drives: Neptune GR86
What data are you using to say it runs better (I know, you said "like") with the UEL vs the EL tune? The OFT tune looks to be designed around headers that are much more unequal. |
#37 | |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | Bramick (11-27-2014) |
#38 | |
Drives: Raven FR-S 6M
Wow that is the most incorrect information I have seen. The vvt is different for a reason. Why would an EL tune be better on a UEL? The tune was optimized for best power on EL. The UEL tune is optimized to have the vvt produce the best hp and tq for UEL hence the different name.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | Andrew025 (11-27-2014) |
#39 | |
Last edited by KoolBRZ; 11-27-2014 at 05:16 PM. Reason: I removed the proprietary pictures of the VVT tables. |
#40 | |
You know nothing about how or why the tables are different. I have looked at our tunes in romraider many times and wouldn't assume one is more agressive just based on the intake or exhaust cam angles. They correspond to how much overlap and/or angle is needed to have efficient scavenging for each header type. Comparing them to determine agressiveness is not really logical. The typical tuning strategy is to adjust those tables to make the most power through the whole curve for that header. Having to flash EL tunes on manual trans with UEL headers get better power is even more illogical. HP and TQ requirements are the same with auto or manual. Also Shiv's tunes are really proprietary if anyone can download them for free off his site.
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 11-28-2014 at 01:32 AM. |
| The Following User Says Thank You to Apoc For This Useful Post: | cdrazic93 (11-28-2014) |
| Photos of new MXP equal and unequal length header + overpipe | No Limit Motorsport | Engine, Exhaust, Transmission | 8 | 10-19-2015 12:59 PM |
| Tomei Headers Special! Unequal or Equal Length! | Aristocrat Autosport | Engine, Exhaust, Bolt-Ons | 15 | 08-18-2014 08:02 PM |
| WTB: Unequal Length Headers | FRS_Jack | Want-To-Buy Requests | 3 | 12-08-2013 12:35 PM |
| ?equal length or unequal length headers? | subaruferrucci | Engine, Exhaust, Transmission | 22 | 07-11-2013 01:56 AM |
| unequal length headers | 001BRZ | Engine, Exhaust, Transmission | 10 | 07-21-2012 02:20 AM |
