| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | |
Drives: 2017 CWP BRZ Performance Package
^ I do this quite a bit now, and I feel the same that it makes the shifts much smoother... not sure if this would hurt the clutch though since you're still giving a bit of rev while you're shifting can anyone confirm or deny? |
#30 | ||
SPACESHIP
Drives: BRZ Ltd 6MT WRB
#31 |
Drives: 2015 Series.Blue
I've been driving manual for almost 20 years and yes there is a learning curve with each new car; don't feel bad about it or let others give you a hard time. That being said there are always things that you/I can do better. Been covered above pretty well. There is also a difference in not getting smooth movement during shifts and the gearbox being more difficult going into gears, especially at low temps. The former is easier to change by checking you driving habits and the latter may require fluid changes, etc.
One thing that hasn't been mentioned is adjusting the clutch height to be just a tad lower than the break petal. Takes about 10 min to do and is covered in the DIY section. I really enjoyed the difference this made. |
#32 |
Drives: White FRS, 2011 Cayman, 1986 944
The 1-2 shift is my biggest complaint with this car. Other shifts are generally okay, but not as good as most of the other cars I've owned.
#33 |
Drives: '13 FR-S
Did the problem just surface or has it always been that way?
WHEN I TEST DROVE THE CAR IT WAS FINE |
#34 |
Drives: WRB Limited BRZ
May not be you at all, I'm sure you've seen a lot of people in this forum say something about changing the manual transmission fluid and the rear diff fluid.
A lot of people along with myself would recommend Motul Gear 300 75W90 for the Tranny and Rear Diff. Give your car another month or a couple weeks and then change your fluids and let us know how it is. Edit: I just saw that you said that you had your car since June so I'm sure that car is already broken in. I'd say change your fluids. |
#35 |
Drives: 2013 BRZ Limited White
I appear to have solved my issue by adjusting my seating position and allowing the car a few minutes to warm up. I had already found the sweet spot, but I don't like having to stretch/extend my foot to push the clutch all the way to the floor, so I kept trying to move closer which throws off my rhythm/distance.
I seem to go through this battle with every manual, and I always end up conceding defeat and accepting that I'm just not going to be able to put clutch to floor flat footed, have to use "tippy toes". I guess I just have to accept that I've got some short ass legs. I do plan on swapping out fluids for motul 300 at some point, but it'll have to wait because the wife is getting really annoyed at my "just one more thing" mentality for car extras... |
| The Following User Says Thank You to MikeM7 For This Useful Post: | chaoskaze (01-27-2015) |
#36 |
The Fail Boat
Drives: CWP S.B.
From my experience you just need to shift without hesitation and it's better to roll the gear in instead of pushing it. I also noticed that if I sit really upright in my seating position.......It shift better..........>__>.
^also one more thing to be improve = our FRS/BRZ journey =p |
#37 |
Drives: '13 FR-S
As you discovered, you should push the clutch in all the way to the floor to guarantee disengagement without having to think about it. By not going all the way to the floor, you're "floating" that clutch foot and never have the same engage reference point.
#38 |
Dismember
Drives: 2013 Red Scion FR-S
It's a hard car to shift smoothly, but it can be done. Poor clutch feel for sure. Not that bad, though. You just have to pay attention!
#39 |
Drives: '15 Brz Series Blue
honestly imo different shoes provide for different ride smoothness. nikes or tighter fitting smaller width shoes make for easy shifts where as skateboard shoes like vans or dvs (whatever your preference) make shifting rough sometimes and hard to feel the clutch release. but as always practice and wear make easier shifting.
#40 | |
Drives: 2003 S2000, 2008 Fit
Once you have that, shifts can become very smooth (passengers have remarked that they didn't know I was driving manual at all). And yes, as others have noted - not letting off the gas completely seems to help with smoothness - experiment! I don't think it should cause too much clutch wear, since I'm assuming you're shifting at reasonable RPMs for moderate/easy driving (i.e. I shift at 2k-3k), so it shouldn't cause ridiculous slip... |
#41 | |
Drives: '13 FR-S
The original poster is talking about "choppy shifting." I actually don't know what that means. THere are two problems here, they are caused by different things: 1) Rough engagement upon clutch uptake 2) Notchy shifting in the gear box upon moving the stick I have a feeling most people here are talking about the shifter, and most people are not fully disengaging the clutch. That can definitely cause the problem because gear is still loaded and not wanting to let go. Even the most expensive Porsche or BMW will drive like shit if you have an untrained left foot. The good news is that it's all technique. "Manhandling" the stick a last resort. |
#42 | |
| shifting from 1st to 2nd | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 05-26-2016 08:15 PM |
| shifting into 2nd | cantaloupe | BRZ First-Gen (2012+) -- General Topics | 63 | 06-23-2014 05:47 PM |
| Shifting into 2nd | bpmorgan7 | BRZ First-Gen (2012+) -- General Topics | 31 | 04-11-2014 05:39 PM |
| MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 04:28 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
