| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#85 |
Drives: 2013 FR-S Hot Lava
Whatever you do, get winter tires!!
I changed back to my summer tire in April of this year and then an unexpected snow storm popped up in CT one day. I had my first crap-pants moment. I was waiting to merge onto the main road from my neighborhood while stuck boots-deep in crap... I mean snow. I step on the gas, nothing. I punch it and whoa, all of a sudden I'm in the opposite lane and the car doesn't want to straighten out. So, I'm driving sideways up a hill at 5 mph with a shit load of cars behind me. Holy shit, worst 5 min of my driving career... Anyway, I already drove the car for two winters. It does well on proper winter tires. Don't cheap out or it will cost you more in the end.
Live to drive another day
#86 |
Drives: 2013 Subaru BRZ limited 2.0l
I'm winter driving my brz, I have winter tires on some blizzaks, I went a little bigger for the clearance as the roads here are crappy, I work at a camp job so the car sat in a parking lot for 9 days. When i got to here I passed by it once due to so much snow couldn't see the car. brushed it off a little and started it up, heated seats on and brushed off the rest of the snow. ( push button start is a little annoying to have to sit in when you just want to start it and go. ) After warmed up plowed a little snow with out problems, no spin out at all. Did some shopping for food today, found snow falls down in the trunk when you open it other than that still lots of fun, full control great car
| The Following User Says Thank You to Spartiduck For This Useful Post: | Stang70Fastback (11-28-2014) |
#87 |
Drives: 2018 Subaru BRZ Sport-Tech RS
http://i.imgur.com/mcxGPFK.jpg
Check this picture, I've been running in Montréal on my Nokian Hakka 7 since february last year. They're not great on asphalt above zero degree celcius but they are awesome on snow and when the temperature gets really low (-10 to -40c). I see a lot of FR-S going around in Montréal during winter, we're all doing fine. The car is not very good for driving on the highway during a snowstorm though... so it's probably better you keep of the road when that happens.. ![]() I'm a sales guy, I travel a lot between Montréal and Ottawa and I'm doing fine with my BRZ as my daily driver!
Last edited by Ezk1el; 11-28-2014 at 12:49 PM. Reason: Forgot to include the img in the post |
| The Following 2 Users Say Thank You to Ezk1el For This Useful Post: | Ganthrithor (11-28-2014), slaxx (12-03-2014) |
#88 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Just installed Bridgestone Blizzak LM32s on my stock wheels and installed Weather tech floor liners. I want to get a few sandbags to put in the trunk for snow days but until then I'll probably use a few plates from my weight set.
#93 | |
Drives: FR-S Whiteout 2013
Just installed Nokian hakkapeliitta R2. Factory rims.
In a straight line, they will break traction if over powered, but remain pushing forward. To do this, though I had to really over power them (in slush). We also had cold rain (about 40F) that day and it would break traction a little early in a straight line (from a stop), but did not slide in the rear. That's comforting compared to how the stock tires did last winter - they would break traction in a straight line in snow and slush then would slip usually right given the crown on most roads. In turns, the new tires seem to hold nicely so long as throttle management is smooth and appropriate power to complete the turn. Didn't try much over-powering in turns or braking. Need to wait to practice in a larger open space. Here in the upper Mid-Atlantic, our winter conditions vary a lot from the occasional blizzard to cold rain. We often get icing and mixed sleet/snow conditions. From my research, the Nokian R2 rated best for ice and snow whereas most winter tires seem to excel at one or the other, not both. Apparently no winter tire excels at all winter conditions. It turns out it's best to gravitate toward the conditions you encounter the most. As for dry roads, they make the handling feel a little more like a regular car. Steering inputs feel dampened, the ride feels notably softer - particularly on rough surfaces. Road noise is lower in the mid-frequency bands which is easier on the ears. There is a little bit of audible low-frequency hum from the knobby type tread - but nothing like a jeep or SUV. |
| The Following User Says Thank You to Thrilled For This Useful Post: | Ganthrithor (11-29-2014) |
#94 |
New Winter issue, So in laws didn't clean the snow from the driveway very well so i did some minor plowing with the BRZ. Today I went to drive the car and just spun out, could back up a little but not much, wasn't in very much snow. Got out and found front tires not turning when backing or going forward. Breaks frozen so dragging front end. The fix was turn off traction controls and spin back end until hit pavement, "Clunk" break free and away I go. The next few stops each had lesser "clunks" as the ice melted away. Washed the car and should be good.
#95 |
Drop
#96 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
After that one episode, I ALWAYS clear out all four fenders when parking my car if it's that kind of build-up. Sometimes I would get lazy and not clear it all, and then if anything the next morning would suck because I wouldn't be able to go full lock on the steering without rubbing against solid ice, and I couldn't exceed 50 MPH on the way to work because the vibrations from the snow build-up in the wheels were so bad, lol. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Ganthrithor (12-21-2014) |
#97 | |
#98 |
A.K.A. Starlord
Yeah. It isn't really a problem unless it drops below freezing overnight and you park outside like I used to. It isn't something you really think about until it happens, lol. The bigger the vehicle, the bigger the ice block you'll have to chisel away, lol.
| Winter Driving? | project d | CANADA | 383 | 01-28-2014 08:52 PM |
| Why winter driving is so much fun in this car | Suberman | CANADA | 5 | 01-25-2014 01:48 PM |
| winter driving | jmaryt | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 11-11-2013 12:15 PM |
| Winter Driving Tip. | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2013 06:38 PM |
| winter driving | paraguin | BRZ First-Gen (2012+) -- General Topics | 25 | 08-03-2012 06:26 PM |
