#15 | |
Drives: FRS
I agree I should talk to professionals. I was hoping a few would chime in as we have some high level guys bouncing around the forum. So, professionals, any advice given my criteria? |
#16 |
Have you considered the Bilstein B14 coilovers?
If you want something with linear springs, I would start building from there rather than going with a sleeve kit over the fixed perch Bilstein offerings. - Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#17 | |
Drives: gt86...among others
We have similar parts and car is also a DD with track days. Ohlin R/T's have been excellent and reliable. Standard springs(380lb) that come with them work well for tires with treadwear 100+ on track days. Anything stickier and the springs begin to feel soft. With PSS tires and R/T's we can leave the track day camber and toe settings for DD. High camber doesn't seem to hurt the the PSS's much, just a little white noise while highway driving. The only suspension change after a race are the clicks on the shocks. 3-7 for track days, 14-18DD. Happy hunting.
racing gods live deep in corners
#18 |
Drives: FRS
Would I do custom spring rates? And would I need a re-valve? Do you know anyone that could help me with that? Maybe someone who is a vendor? On PM perhaps?
#19 | |
Drives: FRS
#20 |
RS*R owns #1 and #2. You'll want camber plates for the RS*R though.
#21 |
If you swap the upper mount on the RSRs and have a camber bolt for the front would that give enough camber?
#22 |
How much camber are you looking for?
#23 |
Drives: '23 BRZ Limited
Have you looked at the Ground Control setup?
I was a big fan of setups I had on a couple of different BMWs. The height adjustment mechanism is also much tidier than the lock ring setup. |
#24 |
#25 |
Drives: FRS
I like the design of the RSR top hats. They are fixed and rubber, so they should be quiet. They also can be rotated to produce 0 or -1.5 degrees of camber. I imagine if you set them at -1.5 and used camber bolts you could get to -2 or -2.5. That would be more than enough for my application.
#26 | |
They're still good coilovers with the progressive rates, just more of a street thing. - Andy
Website
#27 |
Drives: FRS
Maybe picking up the Bilsteins and running them for a while is a good option. Then I could rebuild to different specs down the road.
How do the B16's compare to the iSports? I like that the B16's can be rebuilt. I would have to buy top hats, however. |
#28 | |
The Sport-i is a surprising coilover. It's not exactly extravagant, but it works exactly for its intended goal. |
| Picking up BRZ tomorrow... | sub_stance | CANADA | 17 | 03-25-2013 01:48 AM |
| Need help picking coils | WolfsFang | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 03-11-2013 10:31 PM |
| Anyone picking up a Nexus 4 or 10? Available Now | ironchef | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 11-13-2012 02:19 PM |
| Picking her up at 5! | remorse87 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-07-2012 11:51 AM |
| Need Help Picking New Phone | Calais | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 02-22-2011 05:29 PM |
