Old 07-23-2015, 02:11 PM   #15
protpibe
protpibe's Avatar
Originally Posted by matthui95 View Post
Wouldn't mind it sticking out a bit, part of me kind of likes that lol. I guess I'm just getting confused by that thread .. guys were making it seem as though it's 110% impossible to have 18's on a lowered car.
And what do you mean by "angle inward"? As in camber?
The tire sidewalls would have a tiny bit of stretch to them, instead of being straight up and down
The Following User Says Thank You to protpibe For This Useful Post:
TheWhiteWizard13 (03-29-2017)
Old 07-23-2015, 02:21 PM   #16
matthui95
matthui95's Avatar
Drives: 2018 CWP Subaru BRZ Sport-tech RS
I'd probably end up running 18x9, but I do like the look of a bit of stretch.
Last question and I'll stop bothering you lol Why does the red top plate in your picture seem misaligned from the actual bag? It almost seems as though the bag has been shifted inwards towards the wheel well and is up against the wheel well.
matthui95 is offline   Reply With Quote
The Following User Says Thank You to matthui95 For This Useful Post:
Old 07-23-2015, 02:47 PM   #17
protpibe
protpibe's Avatar
No bother at all
The top hats are adjustable for camber and you can adjust how they sit
The Following 2 Users Say Thank You to protpibe For This Useful Post:
matthui95 (07-23-2015), TheWhiteWizard13 (03-29-2017)
Old 07-23-2015, 03:13 PM   #18
matthui95
matthui95's Avatar
No bother at all
Ah, I completely forgot. Do your wheels automatically tuck in from camber when you drop the car to it's lowest setting? If so, how does it do that?
Old 08-04-2015, 03:03 PM   #19
protpibe
protpibe's Avatar
Update:
265/35/18 DOES NOT FIT with +33 lol
Under heavy compression the tire contacted the bag very slightly and wore into it. I've since replaced the air spring (VERY cheap and VERY easy to replace), and ordered 30mm wider fenders + spacers. Lesson learned, and I hope others learn from it haha.
For what it's worth, Air Lift recommends 1/2" clearance between the bag and tire to allow for expanding.
Old 09-16-2015, 05:22 PM   #20
Vroomin86
Drives: 2015 Fire
Update:
help a new airlift owner out with an update
I am running 18x9+35 squared on 245/40 and 265/35
Am I fucked clearance wise? I am scared to make the two hour drive for install and then my wheels don't fit back on....
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 09-16-2015, 05:37 PM   #21
protpibe
protpibe's Avatar
I meant that as a warning for fronts. I think you'll be ok with 245 as long as your offset is fine
Old 09-16-2015, 06:20 PM   #22
Vroomin86
Drives: 2015 Fire
its a 245/40 on a 18x9+35, think I will be able to air out all the way? also do I have to replace any suspension components?
Sorry for all the questions man, just afraid ill tear some shit up and thank you
2015 FireStorm FRS
Old 09-16-2015, 06:30 PM   #23
protpibe
protpibe's Avatar
You should be fine, just make sure you're not running camber bolts because it will push the strut into the tire.
The bag touching your tire while aired all the way out isn't that big of a deal. it's the air bag touching the tire while it's inflated and you're moving that's the issue.
LXXXV1 (12-21-2015)
Old 09-16-2015, 06:51 PM   #24
Vroomin86
Drives: 2015 Fire
glad you told me that bro, as I AM running camber bolts (though not sure their doing jack shit lol )
I will heed your advice. Did you have to pull/roll fenders? I am hoping to not have to but I am asking for a perfect world... I know....
2015 FireStorm FRS
Old 09-16-2015, 06:56 PM   #25
protpibe
protpibe's Avatar
+35 with 245 should be fine without a roll, but test clearance BEFORE you calibrate your setup. Calibration will drop it to 0psi and it might wreck some shit lol
Old 10-13-2015, 07:37 PM   #26
JoeBro
JoeBro's Avatar
Drives: Scion FR-S
Also just a warning, if you plan on maxing camber in the front, there is a bolt coming in from the engine bay on the drivers side that the bag will rub on and eventually pop. Learned from experience lol. Shaved it down seemed to fix that problem
JoeBro is offline   Reply With Quote
Old 10-15-2015, 07:34 AM   #27
thien
Drives: Scion FRS
has anyone tried running 18x9.5 +35 wrapped with 215/40 for the front? any problems? I probably need spacers. and if i get spacers, i need extended studs right? and if i do that i'll just go wide body.... hahah
thien is offline   Reply With Quote
Old 10-22-2015, 08:09 AM   #28
the_kmac_27
Drives: '15 BRZ
I know this thread is mostly concerned with front tire issues, but on the back of the car do you run aftermarket lower control arms to achieve camber to tuck the wheel? If so what brand do you recommend?
the_kmac_27 is offline   Reply With Quote
airlift, bag, cup, suspension, tfworks
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 632 12-22-2023 09:49 AM
Double Exhaust catback system infos Junkwipe Engine, Exhaust, Transmission 25 01-21-2014 12:25 PM
Double Cat Front Pipe? Emissions? swift996 Engine, Exhaust, Transmission 9 01-13-2014 10:29 PM
Essex Competition Brake System (Endurance) fitment on 18x8.5 57Xtremes Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-10-2012 03:08 PM
