#421 | |
Drives: 2013 DGM BRZ Ltd
2. Yes 1:1 with brake should be fine. Just make sure you bleed it fully and that when you're stopped in gear the clutch doesn't grab until you let the pedal out a little bit. You don't want the clutch rubbing when the pedal is to the floor. |
#422 | |
nenber
1 Didnt understand what u said after 'Should be fine.' 2 how so?(the new line performance)what ill feel? Sent from my SM-G960F using Tapatalk |
#423 | |
Drives:
Sent from my SM-G930W8 using Tapatalk |
#424 |
fabulous
You won't feel any difference at all. Don't bother.
#425 |
Drives: gt86
re
Hi,
I want to do the exact opposite, I need the clutch pedal to be softer (easier to press). I know this sounds like blasphemy, but don't pick up the stones just yet ![]() I have spine surgery that bothers me when using the clutch in the GT86. I also have a Mazda3 that is much softer and I have no issues with that. Don't get me wrong, I like the feel of the clutch pedal in GT86 as it is, because is gives much more feedback compared to the Mazda, I just need to make it softer because of the reason mentioned above! Can anyone help me find the right slave cylinder for this? P.S. I tried to find a stiffer spring to replace the OEM but with no success (I have LHD) |
| The Following User Says Thank You to biggie For This Useful Post: | bhmax (08-17-2019) |
#426 | |
Drives: '13 BRZ
#427 |
Drives: gt86
The spring is there
#428 |
Drives: White BRZ Limited
this might be a dumb question. Is there any benefits to upgrading to DOT4 fluid? I know it has a higher boiling point. But can i use that in the clutch fluid resivior? I have to bleed the brakes on my R1 and that requires DOT 4 so i figure. 2 birds, 1 stone right?
#429 | |
fabulous
It would need to have a larger bore than stock 13/16 inch, 21 mm or greater. Depending on your motivation/resourcefulness, the fork could also be extended and the stock slave mounted on spacers.
I don't know about other parts that might fit. This mod was an accidental miracle for me. Quote:
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | jcw99 (04-23-2019), Sgtfluffy16 (04-23-2019) |
#430 |
fabulous
Why I like the assist spring
I regret losing the perch for my assist spring but not enough to scrounge up a replacement. I like the assist spring mostly because it seats the pedal firmly against the top of its travel. Other clutch pedals have a small torsion spring for pedal return. Manufacturers would love to ditch that spring but it's too expensive to make a linkage that doesn't rattle. From a design standpoint, the assist spring is an ingenious little way to make a feature out of an otherwise necessary evil.
Clevis joints are inherently sloppy but they're cheap. So much so that the addition of a return spring to manage tolerance is still cheaper than any other solution. I imagine the moment when a smart guy said "If we have to have a return spring, let's also make it push down on the pedal while we're using it." On the production line, it's relatively easy (cheap) to adequately adjust a linkage that has a little slop. One of the unintended consequences of removing the return spring is that it requires adopting a whole new approach to adjustment of the pedal linkage. We have to actively manage that slop. On one side we have a rattling pedal. On the other we have a rattling master cylinder. I'll get into the latter later. The first requirement of clutch pedal adjustment is that the master cylinder must be allowed to eject the plunger all the way to the stop shim. This is best for the life of the system because chassis noise/vibration is not vibrating the piston. It also guarantees full opening of the equalizing port for self adjustment. Secondly, because we no longer have the return spring to pull the pedal home, we must carefully use the rubber foot as the adjustable hard stop for the pedal itself. The factory adjustment procedure allows for some clearance between foot and switch base. I've found the sweet spot to be when the pedal is at rest, the cruise cancel switch is adjusted so there is almost zero clearance between the switch and foot. Set it to minimize the distance between lifting the pedal away from the clevis pin to where the foot comes into contact with the switch body. I've driven one with an mtec spring. It's nice because it functions well for pedal return, and is less obtrusive. I'd use it If I really hated the assist spring. If I wasn't missing other parts, I'd have long ago reinstalled the stock one.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jcw99 (07-21-2019) |
#431 |
Dismember
Drives: 2013 Red Scion FR-S
When are you coming to the bay area again? I gotta install this but i need your help, dood.
#432 |
fabulous
I promise that I'll let you know before the next time I go down to visit my brother. Let's set up a drive afterward and make a fun day of it.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | EAGLE5 (07-22-2019) |
#433 |
A "fun" day with J? You are optimistic.
#434 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I went back to the OEM slave as I broke my left foot (3 middle metatarsals) and got a stronger ACT clutch. Glad I went back as the new clutch with OEM slave is just as hard to push as the OEM clutch with smaller slave!
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | jcw99 (07-23-2019) |
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 07:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 09:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 11:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 02:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 06:32 PM |
