Old 01-04-2019, 03:30 PM   #407
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by Legend@wheels View Post
As it looks like it has no cons at all - im going for it!!
2 q's-
1 -The big diff is by changing the cylinder alone,right?
Changing the hydraulic line and/or removing spring is just an extra?
2 after doing that where is the most safe position(to make sure no damage will occur in the long run) for the pedal? 1:1 with the brake pedal height is ok?
1 - Yes. This decreases the leverage between pedal and throwout bearing. The stock flexible line is perfectly good. There's no functional benefit to changing it. I have mixed feelings about the spring. I would have reinstalled mine if I still had the parts.
2 - The important point here is to make sure that the clutch adequately disengages. Yes, setting the clutch pedal to match the brake pedal height seems to be ok. Make sure you have maybe 3 cm of extra travel to the floor.
Legend@wheels (01-05-2019)
Old 01-05-2019, 11:45 AM   #408
Legend@wheels
nenber
1 - I have mixed feelings about the spring I would have reinstalled mine if I still had
1 Did u tried that with spring at all?
Maybe its not that effective like it does w/o spring.
2 and how u can know it is?
3 extra from where?
From top pedal to floor ? Easily there is 3cm.
Sent from my SM-G960F using Tapatalk
Legend@wheels is offline   Reply With Quote
Old 01-05-2019, 09:26 PM   #409
Ultramaroon
fabulous
3 cm from floor to clutch contact is where I personally feel adequate clutch disengagement. Others may prefer more decoupling. If that's the case, raise the pedal accordingly.
Legend@wheels (01-06-2019)
Old 01-06-2019, 01:17 AM   #410
Legend@wheels
nenber
Now is hard to tell lol
So vague.
Anyhow as long as i dont hear any noises and/or experiencing any gear grinding(more than usual *shitty boxes*)i guess im ok.
Cheers.
P.s going to order this week the part (aa111 and the washers).
Will not remove the spring at all so i hope ill be pleasant with the the new cylinder alone.
Old 01-06-2019, 02:08 AM   #411
Ultramaroon
fabulous
So vague.
Cheers.
Try coasting forward, clutch disengaged in second gear, engine idling. You'll hear a clunk exactly when the clutch makes contact.
Old 01-06-2019, 02:57 AM   #412
Legend@wheels
nenber
And on that spot lock the height? Or give it another spare 1cm?
Old 01-06-2019, 03:05 AM   #413
Ultramaroon
fabulous
That spot should be about 3 cm from the floor. It can be more but shouldn't be less. It's a feel thing. I push my pedal all the way to the floor when I shift. Some others don't. Those people should adjust the pedal for more travel.
Old 01-06-2019, 03:49 AM   #414
Legend@wheels
nenber
Btw
How does it disconnect from the fork metal?
Cuz i dont see any secure pin/bolt/nut between them -then i assume is just to push it out?
Old 01-06-2019, 03:54 AM   #415
Ultramaroon
fabulous
Pull the fork forward and see. No substitute for hands-on. ...but yes.
Old 01-06-2019, 03:56 AM   #416
Legend@wheels
nenber
Great tnx
Old 01-06-2019, 03:57 AM   #417
Ultramaroon
fabulous
Great tnx
Enjoy
Old 01-06-2019, 10:48 AM   #418
jcw99
Drives: swp mt '14 brz premium
So vague.
Cheers.
I suggest you remove the spring. I started by changing the cylinder only and it was better than OEM and I drove it this way for a good while. After 6 months(?) went by I removed the spring and there was a huge difference. After another 6 months (?) I installed the MTEC spring and I still get great feedback from the pedal but it's much easier to disengage the clutch now. So, I recommend you do the cylinder swap per Ultramaroon's great write-up and also do the MTEC spring swap. Good luck
jcw99 is offline   Reply With Quote
The Following 4 Users Say Thank You to jcw99 For This Useful Post:
Legend@wheels (01-06-2019), Plumbus (08-05-2020), tobin (01-09-2019), Ultramaroon (01-06-2019)
Old 01-06-2019, 09:59 PM   #419
Ultramaroon
fabulous
Changing the cylinder diameter changes both the force and motion profiles. Changing spring rate only changes the force profile.
I suggest that the spring rate is akin to seasoning to taste. Keep your stock parts so you can play around. I've driven all three and I like the MTEC. It just doesn't do that much for me in the context of the swapped cylinder.
It's really quite a subjective topic.
jcw99 (01-06-2019)
Old 01-08-2019, 05:14 AM   #420
Legend@wheels
nenber
Well just done mine.
Definitely Nice one but cant say its earth and sky diff.
In that price its worth it.
The Following User Says Thank You to Legend@wheels For This Useful Post:
Ultramaroon (01-08-2019)
clutch line, slave cylinder
Search this Thread:
Advanced Search
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 07:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 09:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 11:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 02:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 06:32 PM
