#15 |
Remember me?
Drives: BRZ Series.Blue
@FirestormFRS I had a filter while it was on it's just not pictured. It comes with a 3 in to 2.5in 90* silicone coupler.
#16 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Any chance we could get a few pictures of the main components? Uppipe, downpipe, FMIC, etc.
- The Ancient BRZ Sacrament by Zaku |
#18 |
Remember me?
#19 |
Remember me?
#20 |
Remember me?
#21 |
Remember me?
#22 |
Remember me?
#23 |
Remember me?
#24 |
Drives: BRZ LZR
What did you change with the up pipe when you got it reworked?
#25 |
Remember me?
It was angled too close to the frame and would occasionally rub so I had that section removed and straightened. It doesn't rub anymore.
| The Following User Says Thank You to glorydays For This Useful Post: | Guff (11-10-2014) |
#26 | |
Drives: BRZ LZR
Also, are the downpipe and uppipe 2.25" because there is not enough space for larger diameter piping or because that was the optimal diameter? Lastly, did you use a bracket for the turbo in order to support it or is it just held by the uppipe and downpipe?
- The Ancient BRZ Sacrament by Zaku Last edited by Guff; 11-10-2014 at 04:03 AM. |
#27 |
Remember me?
No that was the only issue with the setup so nothing else should be making contact with other parts. The charge pipe almost rests on the alternate but it doesn't bother it at all. If I'd had the resources I would have had all the charge pipes pie cut and welded but it works great as is, just isn't pretty.
I wanted to keep continuity with the oem exhaust system which is why the pipes are 2.25. I figured I'd be using the front and mid pipes for awhile so I didn't think it'd make sense to go 2.5 back down to 2.25. There is room for larger pipes if they are designed closer together but that would require redesigning the entire kit pretty much. There isn't a bracket for the turbo but it is very firmly supported by the front pipe and header. It doesn't move much at all. This kit is pretty much the Works kit only with a larger turbo and FMIC. I think it could be potent in the right hands. |
#28 |
Drives: BRZ LZR
Cool! Another question: As far as the base map goes, do you have a rom that one could flash via a Tactrix cable and ECUflash? What exactly is the base map tuned to in regards to boost, fuel, etc.
| Tags |
| boost, turbo, turbo brz, turbo kit |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 07:36 AM |
| - 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune | aaronsadventures | Member's Car Journals | 6 | 12-04-2014 03:01 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 11:48 AM |
| PTuning Turbo Kit GT3076R BNIB + 3" Exhaust | sw20kosh | Engine, Exhaust, Bolt-Ons | 22 | 02-21-2014 03:24 PM |
| PRE turbo kit (garrett GT3076R) | BRZPDX | Northwest | 90 | 01-18-2014 11:39 AM |
