Old 12-21-2014, 10:54 PM   #15
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Boosted since 34.4K. Lots of AutoX runs. Innovate SC w Delicious CARB tune. Oil changes every 3.5K. Auto tranny fluid change at 40K, 60K. Still runs great.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
The Following User Says Thank You to whataboutbob For This Useful Post:
hmong337 (12-21-2014)
Old 12-23-2014, 01:45 PM   #16
reeves
I'm at 57K miles.. my A/C just went out around 56K miles. O well, i blast that thing 2 hours a day most days, except 2-3 months out of the year.
reeves is offline   Reply With Quote
Old 12-23-2014, 10:39 PM   #17
roddy
roddy's Avatar
Drives: '13 Ultramarine
I'm at 65,000 kms (just over 40,000 miles), and have had a few small issues, but nothing that would make me run away. All were either promptly looked after by my dealership, or were so minor, that I just fixed it myself. Both tail lights have been replaced (one early on and one just a few weeks ago) due to condensation. Both window seals were replaced due to folding up as the window closes. The small 1/4 window at the front of the door on the driver's side has been replaced twice because of a seal flaw. The dash pad material was coming unglued just above the center vents, and again, my dealership was quick to look after it. The only mechanical issue I have experienced was a sticky front brake caliper.
I should add that my car was an early build (April '12), and it is my daily driver. I drive it through all kinds of sh!tty weather, and it is standing up well. I change the oil every 5,000 and the trans (manual) and diff every spring and fall (once per year now that I've settled on what fluids I'm using). The brake pads are just about done at this time...might get another 5,000 out of 'em.
Old 12-23-2014, 11:54 PM   #18
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
On the subject of reliability...
While browsing a store tonight, I was thumbing through a car magazine (can't recall which) with a Forester on the cover. They had some survey of most/least reliable cars. Forester (non-turbo) was one of, if not the top of the small SUV class. BRZ/FR-S took the bottom of the sport car class.
I attribute this to the fact that not so many people are likely to mod a non-turbo Fozzy to the point of blowing up engines. I have to wonder who all they surveyed.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 08-17-2015, 07:58 PM   #19
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Bump, now approaching 60k, still no issues.....anything I should look into having replaced under warranty? I'm about 100-200 miles way from it. Obviously I know it's time to do Spark plugs....not sure what my plan is on that. Already replaced diff/trans fluid. Anything I'm missing?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 08-17-2015, 08:02 PM   #20
1st86 Driver!
If you haven't done it, you could consider having the fuel pump replaced under the tech bulletin.
Old 08-17-2015, 08:16 PM   #21
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Is that really the only problematic thing to worry about? Is there any recall stuff I should go out of my to take the car to the dealer for?
Old 08-17-2015, 08:37 PM   #22
1st86 Driver!
There's a thread on here that lists of service items. There have been only two "real" recalls I believe. 1 was for an error in the owner's manual that they sent out a correction for, and the second was for a very limited number of cars sold in the Southeast that may have had an accessory installed with the wrong torque figures. Everything else is a service bulletin I believe.
I really wasn't having a problem with the fuel pump, the bulletin addresses the "crickets" but I never could really determine if mine did or didn't have them. Still a zeroed out fuel pump is better than one with 60,000 miles on it so I had the dealer check it and they found sufficient noise evidence it needed to be replaced under warranty.
SeanRTR (08-17-2015)
Old 08-18-2015, 01:29 PM   #23
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
50k.
I've put on new front pads, changed air filter and cabin filter a few times.
Changed Diff/tranny fluid twice (once after 1000 mile break in and then again at 20k).
Oil change with Amsoil 0w-30 every 7500 miles with oil filter replacement every 3250 miles.
I think I'll do plugs once I'm north of 75k. They're iridium so there's no hurry to change them.
SCCA T4 - FRS
Old 08-18-2015, 04:55 PM   #24
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
But it's so much fun to change them, why deny yourself the pleasure?
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
Tcoat (08-18-2015)
Old 08-18-2015, 06:13 PM   #25
rice_classic
I'm a sadist, not a masochist.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
Tcoat (08-18-2015)
Old 08-19-2015, 09:57 AM   #26
BRZnut
Drives: BRZ DGM Limited
50k.
I would have thought the Iridium plugs could go 100K miles. So why does Subaru suggest replacing at 60K? Because it's Direct Injection?
Old 08-19-2015, 04:48 PM   #27
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Curious to see what the plugs look like but at this point taking them out you might as well replace them. I'm at 61k and have another set ready to replace but I wouldn't mind waiting a bit longer.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 08-21-2015, 11:33 PM   #28
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I'm closing in at 80k I'll do them soon, post pics if i remember
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Search this Thread:
Advanced Search
2013 - MT - 18k miles - Issues. tbrocato Issues | Warranty | Recalls / TSB 13 10-11-2014 11:49 AM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 10:10 AM
Oft e85 issues sosick Software Tuning 14 05-22-2014 06:40 PM
BC BR coilovers for sale. 3k miles on them with no issues at all! Just changing it up NickFRS Brakes, Suspension, Chassis 11 03-14-2013 03:44 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 09:15 PM
