Drives: 97 Audi A4 1.8 Avant '13 Subaru BRZ
Replacement Lights
Hi guys,
Where can one get replacement fog lamps for the 86, either the normal or preferably the LED ones. Apparently they are an oddly shaped and even toyota doesnt stock them and have to order as and when required. Am asking for a friend of mine who has a blow one. If anyone one know of good LED replacement id also want to replace mine Thanks guys |
Drives: Toyota MR2 Spyder Turbo
I've been trying to figure out the same for a while now.
Will be watching this topic
Official anti-BS squad
Drives: Toyota 86 High 6MT
I've had LED globes in my fogs - they're useless. Pretty in pics but no use otherwise. That being said, the stock ones are also useless so it's much of a muchness I guess. Can get from ebay.com, dx.com, etc...
I've replaced my fogs with glass lens ones & H11 halogens. MUCH better.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
Sav - whats the model number/code or whatever for the LED ones?
H16. You need to modify it a little bit - just cut one of the tabs. You'll see what I mean.
95RON SAV Tuned |
#6 | |
95RON SAV Tuned |
#8 | |
They are actually extremely universal - Renault Megane, Astra OPC, etc - lots of cars using the exact same ones.
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | qbzee007 (11-03-2014) |
Drives: 86HighAT White
Violet electronics stocks led 1s if u interested. I got a quote for R 495 for the 86 led fog bulbs.
#10 |
thanks guys
will stop by at Violet Elect soon
#11 |
Drives: 2014 Satin White Pearl GTS auto
well the stock incandescent bulbs dont do anything in terms of providing usable light, so I also want to replace them with LED ones, so they match the LED eyebrows in the main headlamps.
The PS24W lamps are very hard to get, the last time i went violet they said that they didnt have, If you insist on replacing it with another normal bulb, the Jeeps use the same type. The lamps have different numbers and names depending on which part of the world you are in, as there arent really standards governing them, so 9009, h16, 5202 and PS24w are all the same things. So you guys say violet has them now? maybe diesel and i shoud make a swing by there. also AFAIK the low spec and the hi spec use different bulbs, but i can be corrected on that.
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto |
#12 |
Violet shud have them now.. I emailed about a month ago and they had stock.
#13 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#14 |
Correct, and all those numbers are NOT exactly the same, the tabs/splines are different.
95RON SAV Tuned |
| Valenti / Lexon / Tom Tail lights, Winjet Headlights, Front Bumper lights and Mirrors | Speed Element | Exterior Parts - Lighting | 224 | 12-06-2016 03:07 PM |
| Spyder Automotive OEM Replacement Tail Lights for FR-S/BRZ!! MVP Motorsports | RobertatMVP | Exterior Parts - Lighting | 11 | 04-08-2015 07:59 PM |
| NEW EXCLUSIVE Valenti Tail lights, Winjet Headlights, Front Bumper lights and Mirrors | Speed Element | Northern California | 34 | 01-14-2015 06:32 PM |
| Adding Fog Lights + Headlight Stalk Replacement Void Warranty? | JohnAyySays | Issues | Warranty | Recalls / TSB | 1 | 05-08-2013 10:07 PM |
| Help, looking for BRZ Fog Lights replacement bulb | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 11-14-2012 06:24 PM |
