Member's Car Journals Car journals by our members. |
#1331 | |
Weight Weenie
Drives: 15 FR-S
#1332 | |
Drives:
I vacuumed and blew out any sanding dust that I created. www.instagram.com/zeal.eightsix |
The Following User Says Thank You to zeal86 For This Useful Post: | new2subaru (10-05-2024) |
#1333 |
Drives:
I finally painted the engine but I still need to paint the oil pan black.
I primered, painted aluminum, and gloss cleared the engine using Dupli-Color high heat engine enamel line of paints. I degreased engine surface prior to paint with Spray Nine. I need to order a bunch of seals, o-rings, etc. Also, I did install my Fumoto valve on the oil pan. I will be doing some more polishing and painting of engine parts...those pics will follow soon. Project turned out pretty good...I can't wait to start putting everything back together! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() www.instagram.com/zeal.eightsix |
The Following 4 Users Say Thank You to zeal86 For This Useful Post: |
#1334 |
Drives:
Here I've mocked up my red aluminum intake manifold, polished throttle body, polished fuel rails, polished coolant x-over pipe and painted and cleared engine. Next up is polishing the alternator cradle and the A/C compressor. I will also be painting the direct injector fuel rails anodized red.
I will be ordering a bunch of seals and o-rings for the installation of all the removed components...after those are installed I will put together the engine minus the red intake manifold. I'll wait until the engine is back in the car for that because I don't want to scratch it up with the engine hoist chains. ![]() ![]() ![]() ![]() ![]() ![]() Also, I previously primered the oil pan when I primered the engine, the last pic shows the final results. ![]() I will be building another rolling table with mounts that mate up with the engine. I need to get the engine off the stand in order to work on the Exedy clutch and flywheel. www.instagram.com/zeal.eightsix |
The Following 7 Users Say Thank You to zeal86 For This Useful Post: | BRZyJ (10-24-2024), Busybee (10-23-2024), Code Monkey (10-23-2024), MrSkubi (10-25-2024), new2subaru (10-24-2024), RToyo86 (12-12-2024), Wally86 (11-15-2024) |
#1335 |
Drives: BRZ limited
Amazing work on this!
Looks great! Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Busybee For This Useful Post: | zeal86 (10-23-2024) |
#1336 |
Drives:
Here are a few pics of some components temp installed. I'll reinstall the alternator and intake manifold once the engine is back in the RS1 to avoid damage from joist chains. Verus cam plate is installed and torqued.
I will start installing all the brackets and such that don't require o-rings and seals. I still need to clear coat 3 polished pulleys then clean and paint the tensioner pulley gloss black. Also, I will be installing the painted Verus fuel rail covers. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() www.instagram.com/zeal.eightsix |
The Following 5 Users Say Thank You to zeal86 For This Useful Post: | BRZyJ (10-26-2024), Code Monkey (10-26-2024), KMA KiCKz (10-28-2024), new2subaru (10-29-2024), Wally86 (11-15-2024) |
#1337 |
Drives:
Can't do nice wheels any justice without a big brake kit peeking through the spokes!
![]() A/C Compressor is polished...I'll post pics soon. Also, I just received a bunch of seals, o-rings, grommets, nuts and bolts, etc. for the build. I hope to have the engine put together by the end of the weekend. Next up will be building an engine stand that allows me access to the clutch and flywheel. After that is complete, I will tackle the transmission. I have a Cusco reinforced clutch fork and pivot to install along with a new OEM throwout bearing and other bits. I will be prepping the transmission for paint just like the engine. www.instagram.com/zeal.eightsix |
The Following 2 Users Say Thank You to zeal86 For This Useful Post: | new2subaru (11-16-2024), Wally86 (11-15-2024) |
#1338 |
Drives: Toyota GT86
Did you go Blitz because of MF ghost ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#1339 |
Drives:
I don't know what MF Ghost is so no. What is MF Ghost? Sounds like an anime title.
#1340 |
Drives:
Btw...I finally posted a bunch of parts for sale...see them here...
https://r.tapatalk.com/shareLink/top...ink_source=app I'll be prepping some more items for sale soon... www.instagram.com/zeal.eightsix |
#1341 | |
Drives: Toyota GT86
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
Kylefrs Build Thread | kylefrs | Member's Car Journals | 14 | 01-28-2015 09:27 PM |
Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 08:09 PM |
EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 08:34 PM |
