Old 04-27-2016, 06:39 PM   #379
zeal86
zeal86's Avatar
Drives:
Not completed but definitely more progress...
So purdy...
Waiting on some parts that are getting bead blasted... I still have some polishing to do. The big stuff is out of the way though.... I'm glad about that! Can't wait to crank her up!
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 6 Users Say Thank You to zeal86 For This Useful Post:
Clipdat (04-28-2016), craigpitts7 (05-01-2016), Irace86 (04-28-2016), Koj (09-06-2016), Lococholo84 (04-27-2016), weederr33 (04-29-2016)
Old 04-28-2016, 12:52 AM   #380
notout86
Drives: GTS 86 auto
I have learned so much from your build. From now on I will do NOTHING to my car until I have referred to it.
You have mentioned you only ever use water from the hose. Same with me. Our mains water is particularly "hard" i.e. contains salts. Afterwards, while anything is still wet, I rinse with water from our rainwater tank which is close to distilled water.
When you post profile photos of your car would you mind having the lettering on the tyres right at the base where it looks best (although upside down).
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
The Following User Says Thank You to notout86 For This Useful Post:
zeal86 (04-28-2016)
Old 04-28-2016, 01:27 AM   #381
zeal86
zeal86's Avatar
Drives:
Some more pics from things I did today...
Traction fluid filter assembly
Edit: I had to go back and install an insulator sleeve I missed. That sleeve is not pictured above or below.
Sleeve installed...
Installed to bracket under GT Supercharger...
Polished a few of these... I only used Blue Magic and my Dremel with felt wheel...
Secured and heat protected the fan shroud connectors...I'm going install more heat barrier tomorrow...
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Old 04-28-2016, 01:49 AM   #382
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Thank you for doing all these awesome things that I'm way too lazy to do. Would love to see your car in person when it's all finished!
Originally Posted by humfrz
I'm old and lazy
zeal86 (04-28-2016)
Old 04-28-2016, 02:18 AM   #383
Irace86
Drives: BRZ + Ducati M796
Looking awesome man.
Irace86 is offline   Reply With Quote
The Following User Says Thank You to Irace86 For This Useful Post:
zeal86 (04-28-2016)
Old 04-28-2016, 10:30 PM   #384
zeal86
zeal86's Avatar
Drives:
Well...while inspecting my install I noticed my v-belt was incorrectly placed from the top on my SC pulley but not at the bottom... I fixed that but during my inspection I found that the dip stick boss I thought I cut down to 5mm was off by a couple of millimeters or so and contacting my SC pulley.
So... I'm going to release the tension on the v-belt and the bolts on the supercharger bracket then push it back and see if I can create enough space to file down the boss or use a mini hacksaw... crossing my fingers! If not, off with the bracket...
The Following User Says Thank You to zeal86 For This Useful Post:
Koj (09-06-2016)
Old 04-29-2016, 10:33 PM   #385
zeal86
zeal86's Avatar
Drives:
Problem solved! I masked off the pulley with aluminum tape then took a mini hacksaw blade to the boss. There was plenty of space to saw off the boss without marring up anything around it or the pulley.
Koj (09-06-2016)
Old 04-29-2016, 11:11 PM   #386
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Lookin' good so far!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
zeal86 (04-29-2016)
Old 04-30-2016, 11:28 PM   #387
zeal86
zeal86's Avatar
Drives:
Got my parts back from the bead blaster yesterday... some went to the powder coater, some I polished or will polish...
Here is one I polished today... my Beatrush front beam brace...
Ready for polishing...
Polished...
Temp installed...
I was able to save the decals... backed them with a super thin 3M double-sided tape...I will place them tomorrow...
Koj (09-06-2016), new2subaru (05-01-2016)
Old 05-01-2016, 03:08 PM   #388
zeal86
zeal86's Avatar
Drives:
Traction fluid reservoir mounted to the (separated and powder coated) radiator support bracket.
I will begin polishing the top portion of the radiator support bracket in a few.
Koj (09-06-2016)
Old 05-01-2016, 03:16 PM   #389
zeal86
zeal86's Avatar
Drives:
Decals reinstalled... just like from Beatrush...
Old 05-02-2016, 07:02 PM   #390
zeal86
zeal86's Avatar
Drives:
Had to come to a stopping point (for now at least) ... anyway... this is where I am at...
After being bead blasted...
I still have plenty of polishing to do... but this pic gives you an idea how it will turn out.
Instead of drilling 4 holes (2 ea) for the zipties to pass through as per the instructions, I drilled 2 holes (1 ea) and riveted in some ziptie tie-downs.
Koj (09-06-2016)
Old 05-03-2016, 12:40 AM   #391
zeal86
zeal86's Avatar
Drives:
Finished polishing the radiator support bracket today... now I have to decide how I am going to protect the steel from rusting... I'm going to either have it powder coated or have it painted with an automotive clear coat.
Check out the reflection of the popcorn ceiling...
The Following 5 Users Say Thank You to zeal86 For This Useful Post:
8R6 (05-03-2016), Clipdat (05-05-2016), Koj (09-06-2016), new2subaru (05-03-2016), weederr33 (05-03-2016)
Old 05-03-2016, 10:16 AM   #392
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
JEZUS !
wnt3d is offline   Reply With Quote
The Following User Says Thank You to wnt3d For This Useful Post:
zeal86 (05-03-2016)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
