#15 |
Drives: Wrb brz
#16 | ||
Changing Oil Brands and Winter
Motul 300V or Motul 8100? It's ok to mix API certified oil, or oils made to API specs (Motul 8100), as they must pass ASTM D6922. Quote:
The cold cranking viscosity of 0W is measured at -35C and the cold cranking viscosity of 5W is measured at -30C. In both cases, this is regardless of what the second number is. http://www.pqiamerica.com/coldcrank.htm I guess you could say that 0W is more of the winter grade, but 5W will cover some very cold temps as well. -Dennis Last edited by bluesubie; 10-30-2014 at 11:00 AM. |
#17 | |
Drives: '23 BRZ Limited
What empirical evidence are you basing this on? The trend toward lighter oils is because of better machining tolerances and the need for better fuel mileage (lighter oil = less drag on internal components = less lost HP). |
#18 | ||
The owner's manual? We're definitely
and but in certain driving conditions (like the track as mentioned) the owner's manual absolutely allows it.Quote:
A 10W-30 may not be needed, but it's certainly allowed and 0W-20 is recommended for fuel economy. -Dennis |
#19 |
I ran 0w20 on the track this year with no issues, other than some relatively high oil temps.
I am definitely getting an oil cooler and may consider 5w30 for track season. IIRC, the heavier oil will result in more wear until it comes up to temperature, which will take longer. So there's a tradeoff. More wear vs high temp performance. |
#20 | |
That's not from me, that's from engineers at bobisthoilguy. ![]() OTOH, thinner oils provide better cooling and have shown to result in lower oil temps at the track. But that's not the topic of this thread!! ![]() ![]() -Dennis Last edited by bluesubie; 10-30-2014 at 01:19 PM. |
#21 |
Drives: 14BRZ
Thanks for all the opinion everyone.
Now question is. Thicker or thinner oil for daily driving during winter? Averages around -20 degrees in my city during winter ALSO, I have a drop in filter currently in my car. Should I switch back to stock during winter? Last edited by sixthree; 10-30-2014 at 03:13 PM. |
#22 | |
Drives: Wrb brz
#23 |
Drives: Wrb brz
Personally I would run a 5w30 in the summer And a good 0w20 like redline would be fine for the winter. The drop in filter is irrelevant you don't have to change it for weather conditions.
| Gauge Brands? | Khorne | Electronics | Audio | NAV | Infotainment | 2 | 07-13-2014 07:49 PM |
| Mixing Oil Brands? | 10Tim | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-02-2014 12:36 PM |
| Changing to winter tires | congee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-28-2013 09:47 PM |
| Clear Bra Film Brands? | @Art_Mighty | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 43 | 10-23-2013 02:49 PM |
| windshield wiper brands? | 7thgear | CANADA | 10 | 01-22-2013 11:23 PM |
