Old 09-19-2012, 06:50 PM   #71
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by Dezoris View Post
I have to ask the obvious here, are you really going to be faster than a stock car with R compound or RS3 with an alignment with a good driver?
I saw this all the time with the S2000 people would dump $$$ in suspension wheels and were so often slower than a good driver with a mostly stock car.
Waiting for results on this. No offense.
Oh just noticed you are in WI you have any autox left up there? I'd like to meet up and see the difference.
Absolutely... KW Variant 3's and some LW mods...and a Performance alignment make this thing Rock..no power mods yet except a Exhaust turndown and K&N Filter in the stock box... 3 Index wins... 1/2 or 1/3 in class and in a 2 day Divisional 2/5th...the alignment made all the difference... oh with some help of some very talented drivers..along the way..and yes...faster than a Stock Car... not sure with one on Rcomps...but I am building mine specifically for ST*..The next Fasttrack should have it classed...
on events: one in Milwaukee this weekend.....and No offense taken..
Bill
Scooby South is offline   Reply With Quote
Old 09-19-2012, 10:43 PM   #72
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I'm going to be keeping my stock wheels for winter tires so I want my summer and winter wheels to have TPMS. Where can I buy TPMS sensors and what should I expect to pay?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-20-2012, 02:42 AM   #73
Dezoris
Dezoris's Avatar
Bill
I found it SCCA Miller Park, I will talk with you then.
Mark.
The Following User Says Thank You to Dezoris For This Useful Post:
Scooby South (04-03-2013)
Old 10-24-2013, 12:17 AM   #74
R3d
Drives: White FR-S
Proof:
Hi,
Id like to ask.
1- that is the stock suspension on this pic right ?!?,
2- Assuming it is, you state that there is about 1/4 inch gap left to clear before the tire rubs. That means about 6.3 mm, and your are running a 17x9+42 wheel.
Then if you had instead a 17x9+50 like in the following thread suggest is perfect flush up front :
http://www.ft86club.com/forums/showthread.php?t=7535
You would be missing at least 1.7mm+ just to be able to make the wheel fit, what do you think ?
p.s: im talking about the front wheel of course!
Thanks
Chris
R3d is offline   Reply With Quote
Old 10-24-2013, 01:22 PM   #75
Scooby South
Conedancer
Originally Posted by R3d View Post
Hi,
Id like to ask.
Thanks
Chris
Hi there,
Yes stock suspension in this pic.. don't know if I would go to a 50... going to crowd a already crowed space between the strut and the tire/wheel.. 42 is just about perfect.. I am running coilovers now.. so there is no clearance issue .. I have 2 sets of wheels both of them are 42 offset.. and now I am running a BBK also.. which the 42 clears perfectly.
for Reference:
Bill
Old 10-24-2013, 02:25 PM   #76
R3d
Drives: White FR-S
Hi there,
for Reference:
Bill
Thanks for your reply !
Say, now that you are running a coil-over setup, have you dropped the car at all ? has the poke changed ( if you lower the car the wheel will go more towards the inside if im not mistaken)?
and are you running the same offset in the back? if so, it must be slightly more flush in the back ?
p.s: how are you liking those stoptech ?
Thanks
Old 10-24-2013, 07:04 PM   #77
Scooby South
Conedancer
Car is dropped about 40mm.. and handling is enhanced.. I have no poke at all.. it not hella flush either. but just about perfect. Running a squared setup.. with 255/40/17 tires.
The Following User Says Thank You to Scooby South For This Useful Post:
R3d (10-29-2013)
Old 10-24-2013, 07:12 PM   #78
Scooby South
Conedancer
oh and brakes are fantastic... did the front and rears..all I can say it freakin stops WAY better than it did with stockers... Lines and fluid also..
Bill
R3d (10-29-2013)
Old 10-25-2013, 11:45 AM   #79
nonicname returns
Drives: 4 wheels
I had Rotas DPT and I bent 3 of them out of nowhere.
I wasn't a fan of them because of that. The lip seems to be not so strong.
just a heads-up
nonicname returns is offline   Reply With Quote
Old 10-29-2013, 03:06 PM   #80
R3d
Drives: White FR-S
on those pictures it does look just perfect ! sounds like +42 is a pretty good size for your application. it even looks like +50 might have been to far inside.
Thanks for the info, your car looks great !!
Old 12-14-2014, 08:03 AM   #81
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
images no workie.
jeepmor is offline   Reply With Quote
Old 12-31-2014, 04:36 PM   #82
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Anyone running these with a 1" drop? (TRD or Eibach pro)
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 07-26-2015, 05:43 PM   #83
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
how come i can't see the pic of the car and wheel on the 1st post?
BRZ RN is offline   Reply With Quote
Old 07-26-2015, 06:18 PM   #84
Scooby South
Conedancer
My bad.....the images expired.. let me see if I can find a place to re-host..
Bill
BRZ RN (07-26-2015)
Wheel Directory: Rota Torque 17x9.0 +30 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 114 09-09-2013 11:19 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! RavSpec Wheels and Tires 2 07-14-2012 11:37 PM
RAYS Gramslight 57Dr - 17x9.0 +35 *** $1399 *** / Pre Order + Group Buy RavSpec Wheels and Tires 9 07-07-2012 03:03 AM
what are your thoughts on rota wheels? VenomRush Other Vehicles & General Automotive Discussions 46 11-24-2009 04:08 AM
