#113 |
Drives: Neptune GR86
Much shame in your general direction.
#114 |
fabulous
#115 |
fabulous
Mustered up the strength to yank it. Immediately felt it backing out of the driveway. The feel is even better but I will say, for a normal sized person, pedal force might be a bit much in stop-and-go traffic.
I'm a bit of a sasquatch. edit: If you don't mind a good manly clutch feel. I recommend both. It feels amazingly direct and crisp. Last edited by Ultramaroon; 11-05-2014 at 07:10 PM. |
#116 | |
degrees
Drives: 6MT BRZ
http://www.mtecind.com/diy/scion-frs...pring-install/ |
| The Following User Says Thank You to 37 For This Useful Post: | jcw99 (11-21-2015) |
#117 | |
Sweeper
I would like to know if this Forester part will be a 1:1 swap? Would love to pick it up rather than go to Toyo of Kirkland ($$$$ plus an hour drive? no thanks!) |
#118 |
degrees
Drives: 6MT BRZ
30620AA111 is a 1:1 swap with the FRS/BRZ slave. It's the same casting with a smaller piston. The slave that @Ultramaroon purchased is for an older Forester, hence why it's not a 1:1 swap and doesn't match at the banjo mount.
You'll also want two new 114130151 crush washers and a small bottle of brake fluid if you don't already have it. Official parts list: 1) Subaru 30620AA111 clutch slave 2) Subaru 114130151 crush washers (x2) 3) Small bottle of DOT 3 or DOT 4 brake fluid Last edited by 37; 11-09-2014 at 10:35 PM. Reason: added official parts list |
| The Following 4 Users Say Thank You to 37 For This Useful Post: |
#119 | |
fabulous
#120 | |
fabulous
Uggh... I don't want to redo the photos but so many people will see it...
#121 | ||
degrees
Drives: 6MT BRZ
| The Following User Says Thank You to 37 For This Useful Post: | Ultramaroon (11-06-2014) |
#122 | |
fabulous
As part of an over-center mechanism, this one works opposite. It is at is maximum compression when the pedal is at rest but doesn't apply any force to the pedal. edit after seeing your edit: Yaay! ![]() I really appreciate the verification. Thank you. |
#123 | |
Drives: 14 Ultramarine FR-S
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#124 |
degrees
Drives: 6MT BRZ
This one? http://www.autozone.com/drivetrain/c...er/383444_0_0/
The list of vehicles looks correct, as does the photo. I'd say it's probably the correct replacement part. Personally I'd rather spend the extra $15 and buy an original. At least you'd know what you're getting. |
#125 | |
That $15 I save is for my OFT fund haha...
#126 |
fabulous
| Are these fake? | shu5892001 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 04-11-2013 01:57 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
| fake Bugatti anyone? | bofa | Other Vehicles & General Automotive Discussions | 16 | 07-18-2011 03:20 PM |
