Old 10-29-2014, 10:23 PM   #15
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by JoeC View Post
Ok, I think I finally got this fixed after deleting almost every single app and disabling almost every android function on my phone with no luck.
Then I went into the built-in equalizer settings in Spotify and changed it to a random (folk to be specific) preset. hit play and boom it worked as normal. Next I went into the EQ settings and turned the EQ off and it was still working as normal. Then I turned the EQ back on and it worked as normal for a couple songs and then back to the original problem. I just turned the EQ off and it seems to be holding working correctly.
So, that's it, turning off the Spotify built-in EQ seems to resolve the issue...
I'll report back to edit this post if the problem comes back.
Thanks again to all those that offered suggestions.
That's weird I have spotify premium also but I don't have a built in equalizer in the app like you mentioned. Maybe its different cause your Samsung and I'm HTC?
brandonblt2 is offline   Reply With Quote
Old 10-30-2014, 01:49 PM   #16
JoeC
Drives: Subaru BRZ Limited
It's in the app settings. I'd be surprised if you didn't have it.
JoeC is offline   Reply With Quote
Old 10-30-2014, 02:27 PM   #17
JoeC
http://community.spotify.com/t5/Spot...di-p/242070#M6
I guess it's a known issue for some folks that the EQ doesn't exist. In my case, it probably would have been better if I didn't have it anyway as it was the source of the problem...
The Following User Says Thank You to JoeC For This Useful Post:
brandonblt2 (10-30-2014)
Search this Thread:
Advanced Search
Bluetooth Volume not Being Saved AmonReviled Electronics | Audio | NAV | Infotainment 0 07-17-2014 04:29 PM
Bluetooth Audio... Loathe it. seannyice81 Electronics | Audio | NAV | Infotainment 35 10-26-2013 03:10 PM
Bluetooth Audio MrMista Electronics | Audio | NAV | Infotainment 14 05-14-2013 10:18 PM
Volume control with Bluetooth audio finch1750 Electronics | Audio | NAV | Infotainment 5 02-17-2013 05:48 AM
bluetooth info, no audio? lbroskee Electronics | Audio | NAV | Infotainment 4 07-24-2012 10:22 PM
