#519 | |
Drives: 2013 Ultramarine FR-S
Even when the Manufacturers say otherwise: From Garrett Website, "Blow-Off (Bypass) Valves The Blow-Off valve (BOV) is a pressure relief device on the intake tract to prevent the turbo’s compressor from going into surge. The BOV should be installed between the compressor discharge and the throttle body, preferably downstream of the charge air cooler (if equipped). When the throttle is closed rapidly, the airflow is quickly reduced, causing flow instability and pressure fluctuations. These rapidly cycling pressure fluctuations are the audible evidence of surge. Surge can eventually lead to thrust bearing failure due to the high loads associated with it. Blow-Off valves use a combination of manifold pressure signal and spring force to detect when the throttle is closed. When the throttle is closed rapidly, the BOV vents boost in the intake tract to atmosphere to relieve the pressure; helping to eliminate the phenomenon of surge." From Turbonetics Website, "Q: Should I run a Blow-Off/By-Pass Valve (BOV) on my turbocharged car? What does it do? A: Yes, all turbo cars can benefit by running a BOV on their vehicle. A BOV works by relieving the compressed air pressure trapped in the piping when the throttle body closes. The turbocharger continues to spin from the exhaust gasses exiting the engine and the compressed air has nowhere to go. The BOV opens and prevents the compressed air from "backing up" onto the compressor wheel causing surge. By venting or re-routing the trapped air, the BOV allows the turbocharger to spool up quicker between shifts and prevents long term damage from continual surging of the compressor wheel."
#520 |
Drives: 2015 BRZ
I think he was referring to a belt-driven supercharger, not a turbocharger. Most modern superchargers include a bypass valve that opens on high vacuum, such as during deceleration. It goes between the s/c outlet & sends pressurized air back to the s/c inlet to prevent surge and over-pressuring of the intake tubing. The only application for an (additional) BOV on a supercharger that I've seen is one that would pop off at a certain boost level to limit maximum boost, so a smaller pulley can be used to build boost sooner w/o exceeding the limit of the injectors and/or engine.
#521 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I like driving!
#522 | |
Of course there are special cases. Low Boost Systems* and Anti-Surge Compressor Housings. Just a question, and I hope they don't take this as an attack or anything. Just trying to learn.
#523 | |
PhoneFlash by EcuTeK
![]() Sincerely, Zach Delicious Tuning |
#524 | |
Not to mention race cars typically don't run bov's either....the contrast to all of this is running a grossly oversized turbo on a tiny motor. That kind of setup can and may produce surge, which is the only time a bov/bpv will provide any sort of benefit. Side Note: Toyota/Subaru specifically tell customers not to run E85 in their cars, but would you listen to them just because they told you not to? Or would you go ahead and get a flex fuel kit and tune anyways because you know it's going to make a good deal of power and the results have been proven? ![]() Sincerely, Zach Delicious Tuning |
#525 |
Thank You for the reply!
| The Following User Says Thank You to DustinS For This Useful Post: |
#526 |
#527 |
Ridge Racerrrrrrrrr
Hey Zach, quick question for you(or anyone who can help me here). I purchased a used electronic boost control solenoid but it did not come with a harness...
I am currently in the process of building my own harness for the kit and the only adapter/plug I need now is the one that would connect to the factory evap sensor wiring. What is the name of that plug/adapter? This way I can just buy one from Canadian tire or princess auto and build my own harness. FYI, I am running a prodrive/HOA 3 port
#528 | |
Sincerely, Zach |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | Infamous Performance (01-26-2016), SkAsphalt (01-27-2016) |
#529 |
Hi Zach & the rest of the Delicious team.
First of all wanted to report that my car has been running awesome on your flex tune for close to 12months now. On and Off track. Chopping plenty of "faster cars" to great amusements. ![]() Anyway I want to try swapping up-to (or is it down to) the 3.125" pulley on my vortech SC. Want to know if this will need a re-tune from you guys? Cheers Solomon |
| The Following 2 Users Say Thank You to felixdecat For This Useful Post: | CSG Mike (01-28-2016) |
#530 | |
Go ahead and send us an email with the following information so I can get you the best answer possible : Which map sensor you're running, how much boost you'd like to run, what gas you're running. You can send this to sales@delicioustuning.com.com. Thank you, and we're glad you've been enjoying the tune! Sincerely, Zach Delicious Tuning |
#531 | |
Ridge Racerrrrrrrrr
#532 | |
Sincerely, Zach |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | SkAsphalt (02-02-2016) |
| P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 02:27 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 12:36 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 01:38 PM |
| February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 01:37 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 12:36 PM |
