Old 02-03-2015, 06:04 PM   #267
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by sales@delicioustuning.com View Post
If you're on an Innovate/Sprintex kit, you're actually most likely on a completely different tune than the Flash & Go. PM me directly with your Dongle ID and we can take a look. Luckily for you, the Tomei EL does actually have some nice potential on the Innovate kits. I'd keep the stock airbox and not install the intake, as we've seen that it heat soaks quickly and tends to kill power.
Sincerely,
Zach
Hey Zach,
Did you guys have a chance to finish the header shootout?
Old 02-03-2015, 06:34 PM   #268
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Calum View Post
Hey Zach,
We're still waiting on a few of the unicorns to the best of my knowledge. Also been sidetracked with getting these Flex Fuel kits out, which is happening right now! More on this to come though.
Sincerely,
Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Calum (02-04-2015), raven1231 (03-03-2015)
Old 02-24-2015, 03:24 PM   #269
DeliciousTuning
Just a quick update. We have refined the Flash & Go tune a bit more for the Sprintex 210+ so you can now run these kits on your FRS/BRZ/86 now and have a tuning solution. We now have a couple of these kits/tunes running in South Africa with FlexFuel too boot. Usually we see about 10% more power on these kits over the standard 210 kits.
We have also implemented the Closed Loop Fueling correction on the 210+ kits along with our own unique traction control configuration for launch control and overall better grip when torque is a problem. It is also scaled with ethanol so as the power goes up the traction control becomes more effective even to 600whp.
[ame="https://www.youtube.com/watch?v=YhWfyl5yoOw"]#RevvProjectBRZ Dyno Session 603hp / 462 ft-lbs with the Subaru BRZ FA20 - YouTube[/ame]
Cheers,
William Knose
Raven604 (02-24-2015), texasbound972 (02-25-2015)
Old 02-25-2015, 01:31 PM   #270
kbye
kbye's Avatar
Drives: 2014 FR-S
Cheers,
William Knose
In terms of stability and smoothness, which tune do you recommend for the innovate/sprintex sc kits, F&G vs. the MAF tune? Can you explain a bit on how you were able to compensate for the intake oscillations getting picked up by the MAP sensor?
kbye is offline   Reply With Quote
Old 02-26-2015, 02:53 PM   #271
DeliciousTuning
We only provide the standard Innovate tune to all customers running standard 210 kits. Only customers running the 210+ kits can utilize the Flash & Go tunes.
Since the stock MAP sensor maxes out at 5psi, and only the port fuel injectors respond to the oscillations you're referring to, we don't see any issue above 5 psi. And below 5psi, we're running almost entirely DI, which doesn't react to the oscillations, so the cars don't run into any issues from it.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
kbye (02-26-2015)
Old 02-26-2015, 06:03 PM   #272
Calum
That Guy
Sincerely,
Zach
I was unaware the 210+ was available for sale?
Old 02-26-2015, 06:20 PM   #273
DeliciousTuning
Yep, if I'm not mistaken you can get the 210+ through Sprintex USA. This mostly applies to our customers in South Africa though. Lots of 210+ kits over there.
Sincerely,
Zach
Calum (02-26-2015)
Old 03-02-2015, 03:30 PM   #274
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Are you guys at work today or super busy? I've been trying to call and even messaged Bill. Would like to get you guys to send me the standard tune for the flash and go with the e85. Need to get the SLOFRS up and running today. Thanks!
texasbound972 is offline   Reply With Quote
Old 03-03-2015, 01:14 PM   #275
DeliciousTuning
We were out of the office all day yesterday in LA, sorry about that.
Sincerely,
Zach
Old 03-03-2015, 01:45 PM   #276
texasbound972
USMC
Thanks Zach. All taken care of. Just need to get a check valve for my catch can asap or route the line to a t-fitting to the intake hose. This setup I have was never intended to see boost. Wish Mike would of told me that.
Old 03-03-2015, 03:01 PM   #277
DeliciousTuning
Hey @projek_01 , you have your profile set so that we can't respond to your PMs. Just letting you know we aren't ignoring you
Sincerely,
Zach
Old 03-03-2015, 06:29 PM   #278
exam2300
Zach and Bill,
I've been trying to contact you guys since last week. I have spoken to Zach and you were to talk to Bill. But at this point, neither one of you have gotten back to me. Someone please get back to me if you are able to perform this upgrade or not.
exam23
exam2300 is offline   Reply With Quote
Old 03-04-2015, 12:33 AM   #279
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Radium does not specify the need for any check valve with their dual can system:
http://www.radiumauto.com/Catch-Can-...RZ86-P374.aspx
That is why none was recommended.
Infamous Performance is offline   Reply With Quote
The Following User Says Thank You to Infamous Performance For This Useful Post:
texasbound972 (03-04-2015)
Old 03-04-2015, 03:29 PM   #280
DeliciousTuning
Originally Posted by exam2300 View Post
Zach and Bill,
exam23
Can you send me another PM or email me directly at sales@delicioustuning.com.com . As soon as I get something I'll have an answer for you. Too many messages, apologize for the delay!
Sincerely,
Zach
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 02:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 12:36 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 01:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 01:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 12:36 PM
