Old 01-27-2015, 02:59 AM   #253
diodelphi
diodelphi's Avatar
Drives: 86
Originally Posted by DeliciousTuning View Post
Some manufacturers do in fact apply CLOSED LOOP under full throttle. Mercedes for example does and I would assume they do not because if the front O2 sensor fails slowly (which they can do) it usually causes them to lean out.
This is why we have ours in development and we are thinking about this as we develop the tune and have some solutions for this when the time comes, that the sensor will fail so it will not run lean.
Cheers,
William Knose
I read a article about subaru ecu's that say subaru ecu's after 2008 have more delay in close loop to open loop transition and they try to limit emissions and fuel consumption .
diodelphi is offline   Reply With Quote
Old 01-27-2015, 12:58 PM   #254
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
This is true and Subaru actually was mandated in 2004 to start applying these techniques by the EPA. In 2004 they had a hell of a time getting the 2004 WRX to not detonate when coming into boost because they were required to run stoich for a period of 2 seconds while at 13+ pounds of boost.
When 2004 arrived and they released the STI, this is when the WRX became a "second class" vehicle under the Impreza lineup and under the EPA rules and regulations were required to run stoich for those 2 seconds. This was not a problem in 2002-2003 because the top of the line Subaru was a WRX at that time.
Now with the new 15 WRX it runs in closed loop for even longer but with better A/F ratios, though still not ideal. We are actually tuning the new 15 WRX to run closed loop 100% of the time now, so we can obtain a more accurate and repeatable A/F ratio.
This is now something we are testing on the BRZ/FRS/86 platforms for improved response, and more consistent A/F ratios.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
diodelphi (01-28-2015)
Old 01-27-2015, 01:03 PM   #255
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
My FSI powered GTI ran closed loop all the time. Made tuning fairly simple and "safe" even at 500hp. Just turn the boost up, check timing pull and go... *i do not recommend this* :-)
Sent from HTC M8 while in burnout mode
cruizin01 is offline   Reply With Quote
Old 01-28-2015, 07:29 AM   #256
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Are you using an oem sensor for this, or 0-5v input from an external wideband controller ?
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 01-28-2015, 07:51 AM   #257
diodelphi
diodelphi's Avatar
Drives: 86
Cheers,
William Knose
I think running 100% in open loop mode is the best way for targeting afr and zeroing CL/OL delay
Old 01-28-2015, 01:41 PM   #258
DeliciousTuning
We have rescaled the front the wideband to closely match the Innovate Wideband O2 in all our tunes. We then use the front wideband for controlling closed loop conditions. Once again as we have stated, this is still something we are testing out right now. I have been running this setup on my daily driver for about 3 months now, refining it each day.
Cheers,
William Knose
SkAsphalt (01-29-2015)
Old 01-29-2015, 01:19 PM   #259
ft86me
ft86me's Avatar
Drives: 2013 FRS
Need to def give @DeliciousTuning a shout!
Flash and go file is absolutely amazing! Car feels very smooth with his tune! Midrange, the car wakes up real quick even under no boost. Car idles like a champ and have no issues with the file what so ever. Most interesting thing is that I went from 12psi to 8psi WOT and have noticed quite the difference in a good way. Much smoother, pulls harder, constant pull even until red. I guess more boost isn't always the way to go! Thanks Bill!
ft86me is offline   Reply With Quote
The Following 4 Users Say Thank You to ft86me For This Useful Post:
DeliciousTuning (01-30-2015), DesertFrs (01-31-2015), JDLAutoDesign (01-30-2015)
Old 01-30-2015, 12:33 PM   #260
DeliciousTuning
Very pleased to hear that you're enjoying your tune!
Sincerely,
Zach
ft86me (01-30-2015)
Old 02-03-2015, 04:52 AM   #261
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
I have just purchased a Tomei EL header. Will I need an update? If so, is the car in any danger if I do take it out for a spin?
Jonesy86 is offline   Reply With Quote
Old 02-03-2015, 10:30 AM   #262
Calum
That Guy
Drives: 2013 asphalt FRS MT
You might want to include what kit you have and any other mods so they can give you a more informed answer.
The Following User Says Thank You to Calum For This Useful Post:
Jonesy86 (02-03-2015)
Old 02-03-2015, 11:19 AM   #263
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
No danger, but you would need an update to utilize the EL's extra HP. If you still have a update left.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following 2 Users Say Thank You to zoth For This Useful Post:
Old 02-03-2015, 12:50 PM   #264
DeliciousTuning
The Flash & Go will adapt to make sure the tune is perfectly safe to run and will gain a little power on its own. However, if you want to take full advantage of the potential gains on the table, it'll likely need an update. Which kit are you running again?
Sincerely,
Zach
Old 02-03-2015, 02:56 PM   #265
Jonesy86
Jonesy86's Avatar
210 intercooled, perrin 2.5 all the way back and stock airbox. (I also have the perrin cai, but have yet to put it on. Catch cans, cusco oil cooler. Advice? Should i pm you my dongle id so you can take a closer look? @Zach
Old 02-03-2015, 03:12 PM   #266
DeliciousTuning
If you're on an Innovate/Sprintex kit, you're actually most likely on a completely different tune than the Flash & Go. PM me directly with your Dongle ID and we can take a look. Luckily for you, the Tomei EL does actually have some nice potential on the Innovate kits. I'd keep the stock airbox and not install the intake, as we've seen that it heat soaks quickly and tends to kill power.
Sincerely,
Zach
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 02:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 12:36 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 01:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 01:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 12:36 PM
