#169 | |
Drives: red frs
#170 | |
Drives: 2013 FRS Whiteout
It wouldn't be the purge control solenoid under the manifold?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
| The Following User Says Thank You to yomny For This Useful Post: | Shit Luck (12-26-2014) |
#171 |
Drives: red frs
#172 |
Just wondering, as im getting ready to install a kit and this is one of the to do's.
#174 |
Drives: red frs
My bov is hanging open at idle and doesn't seem to close when I apply throttle.
#175 |
BOV spring too weak?
#176 |
Drives: red frs
I am having a ton of issues at start up. It won't start without me holding the throttle. It dies at lights too.
Runs great when running but man is idle sketchy at best. |
#177 | |
PhoneFlash by EcuTeK
On 93 octane you would get to about 10 PSI is about as high as you can go before becomes the point of diminishing returns. This would be very close to 300whp. |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | yomny (12-27-2014) |
#178 | |
If your spring pressure is 11 PSI or less it will open at idle. Usually we recommend a minimum of 13 PSI to make sure your have s steady idle. Cheers, William Knose Delicious Tuning |
#179 | |
What wastegate spring do you recommend I use given 10psi or lower? Thanks.
#180 |
#181 | |
Another question I had posted above referring to the comment you made about the map sensors. Which do you recommend using since you mentioned the omni power failing? I've looked around but can't really find any other company that makes a plug and play one for us. Thanks.
| The Following User Says Thank You to yomny For This Useful Post: | texasbound972 (12-27-2014) |
#182 |
USMC
Drives: 2013 FR-S 6-MT Raven
I don't know what website to buy it off of either. Thought I ordered the hondata but it ended up being an omni.
| P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 02:27 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 12:36 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 01:38 PM |
| February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 01:37 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 12:36 PM |
