#141 |
Drives: 13 FRS
Hes been on the dyno the last few days pretty much all day tuning
| The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post: | DeliciousTuning (12-01-2014) |
#142 |
Drives: 2013 raven black fr-s
I'm ordering my tune from them for my efr 6758 build.
Do we have an eta on the flexfuel? |
#143 |
USMC
Drives: 2013 FR-S 6-MT Raven
He builds them by hand with love and care. It might be a little bit.
| The Following User Says Thank You to texasbound972 For This Useful Post: | bakerr6 (11-26-2014) |
#144 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Does the base tune for the Jackson Racing SC take something such as a catted front pipe into consideration? Or would it need a custom tune?
#145 | |
PhoneFlash by EcuTeK
All our Flash & Go tunes are designed around the stock exhaust system (or the closest to that for turbo kits) so as to be on the conservative side. So if you were to install a full exhaust system on the car do not be surprised if you make a little more power without any adjustments. It is expected with our tune especially with better flowing exhaust systems. Now as far as optimal power for your setup it may not be at the limit but it is going to be pretty darn close to a solid tune as the compression is still fairly high to the additional changes will be small as we have seen on the Innovate Supercharger tunes, but they are their if one wants a little more we can tweak the tune a bit for a little more. Cheers, William Knose Delicious Tuning |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | SkAsphalt (12-01-2014), texasbound972 (12-01-2014) |
#146 | |
Ridge Racerrrrrrrrr
Are there any Cyber Monday sales happening current at DT?
#147 |
#148 |
It's turbo time!
Drives: 2013 Scion FRS
#149 |
Drives: RX-7 / BRZ
Can you provide any F'n'G tuned Dyno's for FBM kits? All is see is Avo/JDL/MAP on the site. Thanks.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | Travisty75 (12-02-2014) |
#150 | |
We do have some hanging around, I'll see if I can stop by the shop later and get some of those scanned and uploaded. They make slightly lower numbers than JDL and MAP kits with similarly sized turbos if my memory serves me well. Sincerely, Zach Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | texasbound972 (12-02-2014) |
#151 |
Drives: SWP BRZ
@DeliciousTuning Do we have any updates on the cold weather tunes? I emailed you start up logs as requested and I haven't heard anything for about a week.
Thanks |
#152 | |
We believe we've located the source of the issue within EcuTek's coding, and are working on implementing it into a revision of the Flash N Go tunes. It won't be long now. ![]() Sincerely, Zach Delicious Tuning |
#153 | |
We performed some testing yesterday and forced the intake temp to read below 0 Celsius ("-1") and found that the Engine Load value would get all wonky causing the car to run very poorly as people have noted. When setting the temperature to "0" it will run perfectly, so this is definitely something in the EcuTeK RaceROM Patch specifically with Speed Density VE tables. So as we are speaking to EcuTeK about this for the proper correction to this we have a work around for the time being that allows everything to work properly. So for those of you have these problems, please email me and we will get the temporary fix out. We did send out quite a few revisions to customers around the world, but if you have not received an update and are having the cold start issue and drivability please email us again and we will get that update out to you. Cheers, William Knose Delicious Tuning |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | Efferalgan (12-05-2014), jbravo373 (03-20-2015) |
#154 |
USMC
@Zach@delicioustuning I need that fan shroud. William said you might have one or know where I can get one. Thanks.
| P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 02:27 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 12:36 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 01:38 PM |
| February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 01:37 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 12:36 PM |
