Old 10-18-2014, 05:48 PM   #15
Dipstik-sportech
Dipstik-sportech's Avatar
The full blown kit doesn't come with a thermostat, I haven't seen a need for one honestly.
Old 10-18-2014, 06:04 PM   #16
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
He means oil cooler I hope.
Old 10-18-2014, 06:53 PM   #17
Dipstik-sportech
Me too lol
Old 10-20-2014, 05:27 PM   #18
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Yes the termostat for oil cooler for cold weather
Mikeez is offline   Reply With Quote
Old 10-20-2014, 06:11 PM   #19
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
A must, even then the thermostat lets some oil pass and can overcool in cold weather, i solved that by just blocking the core off with some ally. Depending on how cold it is you may have to do the same or remove the cooler all together, or just drive harder :P
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 10-20-2014, 06:18 PM   #20
Mikeez
Engineering Student
Hahahahaha, drive harder. I like that
Which clutch should I get? FX100 or ACT 6 puck or???
Should I change the diff oil?
Get brembo 4pistons? XD
Old 10-20-2014, 06:27 PM   #21
Dipstik-sportech
Well I'd be doing at least brake pads and good fluid, hauling my car down from 250kph+ taxed the stock brakes beyond their design. The diff oil should be fine. I would go with like the fx300 or 350 or a full face act. if you're not going for big power why have a clutch meant for one? You're just suffering with a stiff touchy clutch for nothing
Old 10-25-2014, 05:25 PM   #22
Mikeez
Engineering Student
You are absolutely right, I don't know what I was thinking lol
The Following User Says Thank You to Mikeez For This Useful Post:
Dipstik-sportech (10-25-2014)
Old 10-25-2014, 10:21 PM   #23
Mikeez
Engineering Student
What about the 6puck ACT, it comes with a flywheel that's well fitted and it supports 345ft-lb of torque just like the fx350. ACT seems more advanced in the technology but clutch master seem to have better material and design...
contradictory? xD
Old 10-25-2014, 11:27 PM   #24
Dipstik-sportech
Are you planning to make 345ftlbs ?
Old 10-25-2014, 11:33 PM   #25
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
My your block rest in heaven if you don't build it lol
Fuck it just get the Exedy twin disk and call it good. It's some $1800 but whatevs.
(You can order the FX400 full face from clutch masters that will hold just as much if not more than the puck faced ACT clutches)
Old 10-25-2014, 11:38 PM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
contradictory? xD
Full face- streetable clutch
8puck- still streetable but less so than the full face
6puck- debatable if streetable or not, based on opinion.
4puck- good luck with that Charlie horse in 20 minutes lol
Old 10-26-2014, 02:08 PM   #27
Mikeez
Engineering Student
I am not sure what you said xD. I am so with the car talk.
When I calculated the power it will release on my setup it will be doing 420 Nm. Which is around 300 ft-lb
Old 10-26-2014, 02:38 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I was talking about clutch styles. The way the clutch is (puck style or full faced) determines how easily you can drive it.
Interesting you say 300lb ft of tq...
HP = T x N /(5252)
HP = 300tq x 7200rpm /(5252)
HP = 411
If you can manage that on 91 gas...
Id go with a full faced clutch. Easiest to drive. Dont get a clutch that is rated for the torque you have, get a clutch thats rated for more tq.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Mikeez (10-26-2014)
Any body have a p&l turbo kit for sale or full blown turbo Anthony7515 Want-To-Buy Requests 2 06-06-2014 06:43 PM
Full Blown Turbo Kit Q & A 69Marshall69 Forced Induction 3 04-18-2014 02:18 PM
fs feeler full blown turbo kit minus turbo kingkai23 Engine, Exhaust, Bolt-Ons 10 03-11-2014 03:59 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
