#99 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
It's the height of the motor being taller is what I'm curious to see on how it affects handling.
#100 |
It's the Mad Cow
Here is a post from another about a completed cars weight with full interior.
http://www.ft86club.com/forums/showthread.php?p=1835019 Trying to do this from my phone is annoying.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#101 | |||||||
Drives: '23 BRZ
That was a perfectly meaningless point to make. Quote:
I seriously doubt we'd see a lot of I8s in place of V8s even if there were no packaging concerns. I6 is a good, workable configuration for a reliable performance engine, and so is V8. Quote:
#102 | ||||
Drives: '23 BRZ
By mentioning the 13B's iron housing you seem to be suggesting that the rotary is heavier than the FA. If that's the case, the LS swap will add more weight than what it adds to the FD. Quote:
I had thought even that might be optimistic, I'm glad to see that it has been achieved. |
#103 | |
It's the Mad Cow
Let me layout the weights: 13B Twin Turbo 410 LS3 6.2L V8 415lbs LS7 7.0L V8 454lbs 2JZ Twin Turbo 580lbs FA20 (Oddly enough finding this is proving to be a pain even those who have asked on the forums can't seem to get an answer) FA20 and Turbo (Since kit's vary I will go with 78lbs for a complete turbo kit with intercooler up front) As for weight changes on the RX7 FD Swaps here is actual weights from stock, ls and 2jz setups. http://www.rx7club.com/other-engine-...eight-1063061/
#104 |
Drives: Whiteout 6Sp FR-S
Ill go out and weigh my engine minus transmission if you want. Just need to make sure my scale goes that high lol
#105 |
It's the Mad Cow
That would be great, try and make sure the intake, ac, basically the accessory's and intake with tb is on it if possible that's how the other are weighed.
#106 | ||
Drives: '23 BRZ
My *point* was that even on an FD, where you aren't adding that much weight, and where the engine is mounted more aft relative to the FR-S, you still move the c.g. forward. On the FR-S, where the delta in engine weights is greater, and where the engine is mounted further forward, you're not going to do any *better* than the swap into the FD as far as movement of c.g. is concerned. And on the FD, like vs. like, c.g. moves forward ~1.5% (like vs. like). Quote:
From my car and what I've been able to gather from other builds, LS swap into an FD, same level of equipment, adds *about* 50 lb. vs. stock and moves the weight forward *about* 1.5%. With other modifications and deletes/additions, you *can* make it lighter than stock with a more rearward c.g., but then you can make the rotary car a lot lighter and move its c.g. rearward as well... |
#107 | |
It's the Mad Cow
#108 |
Drives: '23 BRZ
I've done 12 track days, Texas Mile, multiple 1000-mile plus trips (two between Texas and Rhode Island), 24,000 street miles in mine since I got it in October 2011.
#109 |
It's the Mad Cow
I did 2 motor replacements and got maybe 1000 miles of driving out of each of them and they were not modified. The only difference was I added a bigger radiator and the second time removed rats nest of vacuum lines making both turbos work identically. To be clear this was an FD with the Rotary still in it. The LS1 going in the FRS was originally for my RX7 which already had the hinsin kit installed by that point but the FRS took over.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L Last edited by Cross; 10-17-2014 at 06:18 PM. |
#110 |
Drives: '23 BRZ
Oh, pardon me, that's my LS-swapped FD! I see now you were talking turbo rotary!
#111 |
Thats how she sits now only thing missing is a reluctor wheel and a tranny. Soon as I get a weight ill post it.
| The Following User Says Thank You to C130NAV For This Useful Post: | Cross (10-17-2014) |
#112 |
It's the Mad Cow
I thought it was a little odd then I noticed you had a LS2 FD listed and I felt I should clarify.
| The Following User Says Thank You to Cross For This Useful Post: | ZDan (10-17-2014) |
| stupid yet curious question(fa20 turbo) | friss21 | Forced Induction | 2 | 03-24-2014 08:55 AM |
| nj brand new fa20 turbo kit minus turbo 2500 | kingkai23 | NY / NJ / CT / PA | 3 | 03-06-2014 07:41 PM |
| FA20 turbo exhaust setup. | Baramzisyan | Engine, Exhaust, Transmission | 26 | 02-20-2014 08:58 AM |
| FA20 Turbo? | slidethis | Forced Induction | 23 | 09-27-2013 12:55 PM |
| new jdm legacy B4 uses FA20 turbo | cyde01 | Forced Induction | 3 | 07-26-2012 03:00 AM |
