Old 10-28-2014, 04:50 PM   #85
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Neal@EQtuning View Post
Thats incredibly annoying. So no one has had issues with ACT's?
I was really sad to find out that the exedy clutch requires use of their own flywheel, as I really didn't want the lighter one.
I think there have been one or two isolated cases, where someone did not grease the input shaft at all and different brands (ACT, CM), started locking out people.
BUT, none have been to the extent, where a big percentage of people running the clutch actually have the issue like this one.
I almost bought an OS Giken single disk, but got an incredible deal on an ACT 6 puck I could not pass up.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
The Racers Line (10-29-2014)
Old 10-29-2014, 01:35 PM   #86
aagun
Drives: 86
Originally Posted by RallySTI View Post
The springs are not worn out. The OEM clutch has a long travel damper multi rate spring. These are supposed to be loose. The dampening springs of a clutch disc aren't supposed to be preloaded. These springs will constantly move back and forth while the vehicle is in operation. This is how a clutch disc absorbs driveline/engine harmonics.
my car vibration when i start drive the car
aagun is offline   Reply With Quote
Old 10-31-2014, 03:57 PM   #87
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Curious to see how you like the ACT. They have been really hit or miss with a lot of our built STi's.
The boss and I just got in contact with Southbend. We use their clutches for the wrx 5 speeds and are very happy with them. We have the stage 2 daily for my car and the Enurance for his car on the way now to test out. Will report back when they are installed and broken in.
The Racers Line is offline   Reply With Quote
The Following 3 Users Say Thank You to The Racers Line For This Useful Post:
FrX (10-31-2014), jher (11-01-2014), Sportsguy83 (10-31-2014)
Old 11-02-2014, 05:09 PM   #88
evan
Drives: fr-s
Yes, adjusted on install and after break in period.
Clutch did not do it for first 1800 miles. Just started doing it now.
The thing that jumps to me as a design issue, is that I personally know 6 people that have the same clutch installed and have the same issue at some point and have read of 2 or 3 in forum with the same issue.
Do you remember when I brought up the issues with my ACT clutch doing the same shit and I got slammed by a bunch of know-it-alls blaming it on my installer or on me? Ridiculous. Sometimes this forum is beyond counterproductive. Even the f-body guys could admit design issues with their master/slave setups..
evan is offline   Reply With Quote
Old 11-02-2014, 06:26 PM   #89
Sportsguy83
Drives: Limited BRZ
I don't remember but yea, forums can be really stupid.
evan (11-03-2014)
Old 11-02-2014, 10:21 PM   #90
jher
Drives: 2013 Scion FRS
Mine is starting to have this issue too, now that I'm past the break in period.
jher is offline   Reply With Quote
Old 11-03-2014, 10:44 PM   #91
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I didn't noticed this thread but I experience similar issues with my clutch.
Mine has about 2.2k miles and I followed the instructions.
The issue I had recently its 1st being locked out after a complete stop, also there is some hesitation sometimes.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 11-03-2014, 10:49 PM   #92
Sportsguy83
Drives: Limited BRZ
Wow... so many people...
Draco_PR23 (11-03-2014)
Old 11-03-2014, 10:51 PM   #93
Draco_PR23
Fiebru
Draco_PR23's Avatar
Yes!!!
I knew the clutch felt weird but I didn't expect this and I want to change it!
Current Cars:
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Sportsguy83 (11-03-2014)
Old 11-04-2014, 12:37 AM   #94
Iamthebatman
Drives: Black Subaru BRZ
I have 1k miles on my Stage 1 with no issues yet. Will update in a month or two
Iamthebatman is offline   Reply With Quote
Old 11-04-2014, 10:48 AM   #95
blown
Drives: ft86
PM me your info,I can get a part sent to you for testing to see if this new pin will fix your issue.
blown is offline   Reply With Quote
Old 11-04-2014, 12:10 PM   #96
mike the snake
I read about a lot of people adjusting their clutch pedals lower, which actuates the clutch Less when the pedal is pushed in.
I adjusted mine higher, so the clutch begins actuating earlier, and therefore the clutch opens up more, which may solve these issues some are having.
What I hear complaints about sounds like a dragging clutch, which means either the clutch isn't full disengaging, or there's actually something wrong like an out-of-round disk or bad pressure plate.
I cleared my issues by simply adjusting the clutch.
Old 11-04-2014, 12:31 PM   #97
Sportsguy83
Drives: Limited BRZ
Adjusting the pedal all the way up and all the way down, does not affect the issue at all.
Also, the point of adjusting the pedal low is to prevent overextending the pressure plate, which will in turn damage its teeth really soon. The clutch should grab low, only pressing onto the PP the amount needed to disengange, not more. Adjusting the pedal to prevent overextending the PP is fairly easy and its also easy to know if you are actually adjusting it too low and dragging the clutch.
Old 11-04-2014, 10:43 PM   #98
mike the snake
My point is that many people have clutch adjustments that don't open the clutch enough, causing the dragging clutch and 1st gear issues.
My stock clutch began engaging Juuuuust off the floor. Any more and the clutch would never have fully disegaged and would have hung up and caused the issues many complain about.
After adjusting so the clutch began engaging ealier in the pedal stroke, the clutch ended up opening more, and made it easier to get 1st and improved shifting everywhere.
This, coupled with my tune giving me more gumption just off of idle made it much easier to use.
The stock tune just has no power just off of idle, so it would fall on it;s face when taking off in 1st unless you did everything perfectly, and it also made it difficult to shift smoothly through the other gears.
The new tune has more spunk and better throttle response off idle, which made the clutch much easier to use-no stalling and jerky shifting.
I still have yet to remove my clutch spring, it'll probably make things even better, but I have no complaints with the better tune.
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 08:27 PM
Exedy Stage 2 Clutch alpine Engine, Exhaust, Transmission 21 09-09-2014 01:24 AM
Share your interesting experience when you bought your BRZ/FRS g0ast BRZ First-Gen (2012+) -- General Topics 18 02-25-2014 01:39 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 10:58 PM
