#71 | |
Drives: FR-S Whiteout
http://datazap.me/u/solidone/stg1-20...0&data=1-12-14 No changes were made to the car or tune since yesterday BTW. |
#72 | |
http://datazap.me/u/solidone/stg1-20...4&zoom=236-548 |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (10-09-2014) |
#73 | |
![]() http://datazap.me/u/solidone/stg1-20...5&mark=377-386 |
#74 | |
I cannot say I understand the exact working of the knock control system but the FLKC and FBKC you see are the result of some complex calculation the ecu does based on input from the knock sensor. Then it appears further calculations/timers ect are done/applied and these FLKC detections are applied to the timing for a period of time. sometimes you can see positive FLKC as the ecu returns timing. FLKC appears to be applied to the total timing almost instantly and removed soon after probably if certain condition met since the OFT interrogates the ECU at about 5 times a second its possible it may miss some FLKC events, I generally see all events when logging with tactrix at about 20 times a sec FBKC seems to be the input to the coarse correction calculation and if certian levels and frequency of FBKC occurr then the IAM is adjusted according to the level and frequency of the FBKC detections. Some time later if no or less FBKC is detected the IAM will start to climb towards one again. This is just what I have observed and deduced after reading the romraider explaination's and may not be 100% correct. As I understand it the FBKC and FLCK are events or detections by the knock sensor then the ecu decides what its going to do based on the level and frequency of those detections and what knock correction mode the ecu is working in which aparantly switches so rapidly it can appear to be operating in rough/fine correction mode togeather. their is aparantly a fine learning table FLKC in ecu ram similar to this for wrx Their is some explanation on this over at www.romraider.com (subaru knock correction) its for WRX but appears to hold true for our ecu's Last edited by steve99; 10-09-2014 at 02:37 AM. |
#75 |
#76 | |
Drives: 2013 FRS
![]() Cheers, shiv |
#77 | |
Several spots where there was drop in KC learn without any corresponding FLKC or Knock Correction values... Everything seems to point to error or problem with the latest OFT update. Not to be a ****, but I would have appreciated a response from @Shiv@Openflash. Thankfully we have @steve99 to help. Shiv really ought to pay you for what you do on this forum for OFT users. Instead, customers like myself get ignored, and he only responds to whatever he feels like. WTF, yo?! |
#78 | |
try emailing that stuff to shiv at openflash |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (10-10-2014) |
#79 |
FYI I've emailed shiv before without response. Just not about this recent issue.
#80 |
Drives: White Scion FR-S
@Shiv@Openflash Hey shiv was able to swap over no problem to the new template, I recently picked a phantom ESC, and I am currently running your 2.0 w/1.5 dump E85 ESC UEL Headers Tune, I'm using your boost monitoring tool but its starting at -8.6 psi at idle rather than around 0 , I thought this just might be off 8 psi, but then I did a few pulls and was getting down to -1.8 psi and I am fairly certain this setup isn't capable of making 6.8 psi, I tried turning the car back off and unplugging to reset a few times, but it didn't, I figured I give you a heads up and see what you thought, could be a bad sensor but I will let you know if anything changes over time
#81 | |
Drives: 2013 FRS
#82 |
Drives: 2013 FRS
I do get a fair share of email so I apologize if yours had gone unanswered before. Please email me again. It might also be a good idea to let me know either your actual name or the name you use on this forum so I know who I'm responding too.
#83 | |
http://datazap.me/u/solidone/stg1-20...4&zoom=136-480 |
#84 | |
Drives: 2013 FRS
| Navigation updates | B-R-Z | BRZ First-Gen (2012+) -- General Topics | 48 | 11-19-2014 02:19 PM |
| Openflash manager data display problem. | mid_life_crisis | Software Tuning | 6 | 05-14-2014 10:22 AM |
| GPS map updates? (I-69 Indiana) | BMWDavid | Electronics | Audio | NAV | Infotainment | 1 | 11-30-2012 10:11 AM |
| aus toy updates website | Slide | AUSTRALIA | 7 | 12-30-2011 05:20 AM |
