CANADA Canada
Old 09-29-2014, 01:49 AM   #15
Dango1
Drives: WRB BRZ
Bring back full tank of gas.
Dango1 is offline   Reply With Quote
Old 09-29-2014, 08:05 AM   #16
roddy
roddy's Avatar
Drives: '13 Ultramarine
1. I'm fairly sure (not 100%) That the bottled oil at our local Subi and Toyota dealers is the same as the U.S. versions. The Subaru oil is also made by idemitsu (but a different formula than the Mazda oil), and the Toyota oil (TGMO) is made by Exxon-Mobil. I get my TGMO for about $5/litre for a case of 12 locally, so it is hard to imagine US prices being much less.
2. Pentosin MTF2 fluid. It really helps with the 2nd gear thing in cooler climates. Don't just take my word for it...read through some of the multiple threads in the engine/transmission and fluids threads before you make your decision. I have seen prices as low as $20 and as high as $35 locally for 1 litre, and it is not that easy to find. Someone posted pictures of it on the shelf in the US. It was at one of the big chain stores, but I cant recall if it was Autozone, Pep Boys, or where it was. Something to keep in mind, though, the spec for the transmission is 75W90...Pentosin is 75W80.
3. In most cases, yes...rear diff and trans use a different fluid. A straight up rear diff fluid (GL-5) will contain additives (mainly sulphur, IIRC) that are hard on some metals in the transmission. The actual spec for the rear diff is 75W85 GL-5, with 75W90 as an acceptable substitute. With a Torsen diff like we have in these cars, a limited slip additive isn't necessary, but it wont hurt if it is there. I use Redline 75W85 lightweight gear oil in mine.
Old 09-29-2014, 11:30 AM   #17
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Originally Posted by drewbot View Post
If you're a photography guy, B&H photo is the world's best store.
This, good thing when I was down there they were closed otherwise I probably would have dropped a few bucks there!
tanner is offline   Reply With Quote
Old 09-29-2014, 11:45 AM   #18
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
@roddy Would you mind pm'ing me which dealership you go to for TGMO?
Myv is offline   Reply With Quote
Old 10-04-2014, 05:59 PM   #19
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
Alright guys seems like it's either Mazda in the states or just Toyota local now?
JERM^ is offline   Reply With Quote
Trip to japan, suggest any good JDM FR-S items to bring back? stocktc1 Scion FR-S / Toyota 86 GT86 General Forum 43 02-04-2015 07:23 PM
DetailersDomain.com 01 Porsche 911 Turbo - Bring it back to life. DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 18 06-25-2013 07:26 PM
