#183 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Very good deal. They are quiet and I'd say more comfortable than the VERY hard stock Michelins.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#184 |
Drives: Toyota 86 High 6MT - Pearl White
#185 |
No problem.
The Bridgestones are cheaper and better in every way, I doubt they'd last as long as the Michelins but then probably nothing else would.
95RON SAV Tuned |
#186 |
Drives: Lawn moweR
There was def a 'slight' improvement,
I don't think you would be able to notice a significant improvement in handling, but I have been to Zwartkops for my last 2 track days, so this being the 3rd consecutive time trying it out, I noticed a more comfortable turn in at the hairpin at Turn 2. I can't really substantiate by faster track times, but the feeling is better turning into tight corners. Def worth this mod (Camber bolts)
| The Following User Says Thank You to FT_86_SM_GP For This Useful Post: | sav (11-03-2015) |
#187 | |
Drives: Lawn moweR
I did my first track day this July on stock brakes and tyres, and I know allot of guys that also did this. The learning experience is incredible, and you won't be going flat out(hopefully!), so you should be safe. - Tyres: If you get Potenza RE002's you don't have to have 2 sets for road and track, because you can drive them to work every day and track and you will still get decent mileage compared to semi slicks(daily use). -Brakes: Powerbrake PTA (Endless PB05's) -Lap timing devices: There's a few free apps. I use Harry's laptimer. Ive seen cooler free apps, which shows you your driving line etc, provided you have a external GPS for accuracy.
#189 | |
Drives: Lawn moweR
Agreed with that, Turn 1 - going flat out, I shat myself as a passenger in Kaidans going around turn 1 on 4th flat out Don't think i'll be able to do that anytime soon.Turn 5 and Turn 6: (Table Top) Taking the table top in 3rd gear, I tried to do this in my last session and it was actually by best lap, 1:19.00 - wasn't trying to go flat out, but tried to do something different. At the table top Kaidan goes wide out before he turns in, and a very smooth turn in. (i'll edit his video and try to upload tonight). BTW @Freedom - I was behind you here dude! ![]() You were driving bloody brilliant! ![]() ![]() I can only imagine how much quicker you will be with semi's/upgraded brakes! If you didn't let me pass you, I do not think I would have managed to find a place were I could! 1) Took table top(Turn 5 and 6) on 3rd gear [ame="https://www.youtube.com/watch?v=jWo6PTMmpWc"]Toyota 86 1:19.00 - Zwartkops 1/11/2015 - YouTube[/ame] 2) Took table top Turn 5 on 2nd gear(Got excited to see Freedom) then calmed down and took turn 6 on 3rd gear ![]() [ame="https://www.youtube.com/watch?v=TMWU5-AG_zE"]Toyota 86 - Zwartkops 1/11/2015 - last session - YouTube[/ame] |
| The Following User Says Thank You to FT_86_SM_GP For This Useful Post: | Freedom (11-03-2015) |
#190 |
Drives: Lawn moweR
Extracts from Kaidan's video:
[ame="https://www.youtube.com/watch?v=H1GIUHPh1MA"]Kaidan's 86 coaching @Supertrax 1/11/2015 Zwartkops - YouTube[/ame] |
#191 |
Platinum Member
Drives: Toyota 86 Vortech SC
The real value of camber bolts is they save your tyre shoulders from getting chewed off.
| The Following User Says Thank You to Fish Eagle For This Useful Post: | sav (11-03-2015) |
#192 | |
95RON SAV Tuned |
#193 |
BTW.
Tip of the day - the DOD LS430/460w dashcams have got 5hz GPS with accelerometers. You can then use Racerender to check and overlay your videos.
95RON SAV Tuned |
#194 | |
Platinum Member
Brake pads front - Endless PB05/MX72 from Powerbrake approx R2600. I can make stock pads fade to nothing in 4-5 laps. Brake pads rear - stock is OK Brake fluid (essential because it's high risk) - 2 x 500ml Motul RBF660. Alternately, any other racing DOT4 brake fluid with boiling points higher than 300°C/190°C (dry/wet) Stock tyres are fine for learning (you go farming at lower speeds) ![]() The common apps are Harry's or TrackAddict This is an excellent resource for newbies to tracking - http://www.ft86club.com/forums/showthread.php?t=25485
#195 | ||
Drives: PEARL WHITE GT86 TRD
I noticed that I was about 10km/h faster taking tabletop in 3rd instead of 2nd and it felt like less effort too, pretty interesting. Last edited by Freedom; 11-03-2015 at 09:30 AM. |
#196 | |
95RON SAV Tuned |
| Midvaal Raceway / Zwartkops Skidpan event | Vladror | AFRICA | 4 | 02-01-2014 12:01 PM |
| Tomei Technical Trax Advance LSD on SALE!!!! Powerhouse Racing | Powerhouse Racing | Transmission and Driveline | 2 | 10-07-2013 11:23 AM |
| NOVA SUBARUS - Monthly meets and events. | IloveBaldEagles | Mid-Atlantic | 5 | 09-21-2013 01:41 PM |
