| Member's Car Journals Car journals by our members. |
#29 |
Wish Nissan made one
Drives: '13 WRB BRZ Premium
I got my wheels and tires.. got them on the car last night.. and had a nice little peak of sunlight to snap some pictures today.
NEEDS MOAR LOW.. I'll get the RCE Yellow springs installed in a couple weekends. That will help a bit. Need some tire shine as well.. |
| The Following User Says Thank You to eikond For This Useful Post: | MightyMeeple (03-22-2013) |
#30 |
I installed clear side markers today with amber bulbs.
Also put in a K&N panel filter. I ordered a set of OEM mudguards as well. With the extra width from these wheels I want to prevent rock chips and scrapes down the doors as much as possible. |
#31 |
Drives: 13 BRZ
#32 |
The springs go on this Sunday.. and if time allows.. brake pads, lines, and some aero bits. I did install my front lip last night. I think it looks nice.. definitely makes the front end a little more "angry" and aggressive. |
#33 |
Slower than Fast
Drives: BRZ Limited 6MT
Your car looks great, and thanks for sharing the details and photos. May I ask how the lip installation went? Did you have to drill any, or is it simply blot into place?
#34 | |
I did it myself. I used some double sided tape on the inside most edge so that i could test fit it and adjust.. Once I had it where I wanted I snugged up the tape nice and tight and the held it in place enough for me to start drilling. I started at the two points in the front on either side of the grill and then moved to center and then outside. the worst part was being out in the garage for so long.. brr.. it was like 20* outside yesterday. I need spring!!!! |
#35 |
MOAR LOW
details to follow... |
#37 |
Hot Dog
Drives: quicker than arghx7
Today @eikond & I installed a set of RCE Yellow's on his super clean WR Blue BRZ. Here are some pictures, starting with the "before" ride height:
![]() RYE_6421.jpg by Ryephile, on Flickr ![]() RYE_6417.jpg by Ryephile, on Flickr ![]() RYE_6438.jpg by Ryephile, on Flickr ![]() RYE_6439.jpg by Ryephile, on Flickr ![]() RYE_6451.jpg by Ryephile, on Flickr Here are the "after" pictures: ![]() RYE_6457.jpg by Ryephile, on Flickr ![]() RYE_6458.jpg by Ryephile, on Flickr ![]() RYE_6470.jpg by Ryephile, on Flickr ![]() RYE_6473.jpg by Ryephile, on Flickr There are some suspension stroke measurements I'd like to share. All the ride height measurements are from axle center to the apex of the wheel arch. Note that I forgot to measure the rear motion ratio, so everything I'm mentioning stroke-wise in the rear will be wrong until it gets fixed. Thanks for your patience. Stock Ride Height: 14 5/8" front & 14 3/8" rear Stock damper full droop: 17 7/8" front & rear Front damper free stroke [no bumpstop contact]: 3 9/16" Front stock bumpstop length: 2 5/16" Maximum possible damper stroke [100% theoretical bumpstop squeeze]: 5 7/8" Rear damper free stroke [no bumpstop contact]: 3.0" Rear stock bumpstop length: 2 3/16" Maximum possible damper stroke [100% theoretical bumpstop squeeze]: 5 3/16" RCE front bumpstop: 2.0" RCE front free stroke: 3 7/8" RCE rear bumpstop: 1 1/16" RCE rear free stroke: 4 1/4" RCE Yellow ride height [provisional]: 14.0" front & 13 7/8" rear Translation: The stock suspension has 1 5/16" front and 1 1/16" rear free compression damper travel before becoming bumpstop active. Crazy as it sounds, this is more than many cars in this weight range. The RCE setup with the new bumpstops add back precious free compression travel, at the expense of a more aggressive bumpstop curve. As such, with the RCE setup at its ride height, there is 5/16" less free compression travel in front and 5/8" more free compression stroke in back versus stock. Long story short, the RCE Yellows are about as smart as lowering springs get, in my experience. They keep a reasonable amount of free compression travel, which will keep ride quality decent. The only install notes worth posting is the rear suspension appears to have implemented significant usage of stock rubber bushings put in torsion to add damping to both the control arms and anti-roll bar. We had to use a big-ole-2x4 piece of lumber to leverage the rear suspension to allow the coil-overs to be removed from the car. This suspension tuning strategy isn't terrible per se, but it will reduce the anti-roll bar wheel rate and effective damping level as the bushings wear out. Cheers, Ryan
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
| The Following 4 Users Say Thank You to Ryephile For This Useful Post: |
#38 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
Looks good. Classy mods. How much more do you expect the new springs to settle?
So many modders have more cents than sense!
| The Following User Says Thank You to Rampage For This Useful Post: | eikond (03-24-2013) |
#39 | |
I understand the big 'ol 2x4 part I also understand that despite the lower ride height the I think the ride is smoother and more comfortable. My first reaction was that I thought it was "bouncier".. but after a little more time in the car, it's not that at all.. it's that when you hit big bumps it doesn't bottom out so harshly. It seems to absorb more in the springs before it hits the bump stops. I love the ride.. it feels more connected and more confident. Ryan, you are awesome! Thanks a ton for helping me with this today. I would have been stuck on the rear suspension for a LONG time. |
#40 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
looks very good. Drop lets the car really shine now
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | eikond (03-24-2013) |
#41 | |
I'm fine with it.. sure it's not as low as some of the other kits.. but I've never been a fan of super low dropped cars. With my driveway and the roads around here.. this drop is great. |
#42 | |
Drives: 13 BRZ
It won't settle too much more than your initial drive assuming you got to corner with it a little bit and load everything up. Did you end up doing the RCE sways as well? |
| The Following User Says Thank You to kask2_6.0 For This Useful Post: | eikond (03-25-2013) |
| GrimmSpeed Engineering's Daily BRZ Journal | GrimmSpeed | Member's Car Journals | 34 | 11-13-2013 10:09 AM |
| Longo Scion Demo Build Journal - Car arrives next week | xravexboix | Member's Car Journals | 12 | 06-15-2012 01:00 AM |
| AutoExpress BRZ Review - Follow up to the GT86 Review | Zgrinch | BRZ First-Gen (2012+) -- General Topics | 3 | 12-13-2011 09:03 AM |
| Request for a Member's Journal forum? | ryude | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-30-2011 05:47 PM |
| Wall Street Journal reports 2.5 l engine | Sport-Tech | Engine, Exhaust, Transmission | 8 | 10-11-2010 11:44 PM |
