| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Just buy a clean c6 Vette. Trust me on this one
| The Following User Says Thank You to hmong337 For This Useful Post: | BlackMonarch (09-26-2014) |
#16 |
Drives:
#17 |
Drives: FR-S 2013 Asphalt
Do the swap. This guy ended up getting better weight front to rear ratio and less overall weight on the car with a LS and tran. swap.
http://www.vorshlag.com/forums/showthread.php?p=57906 |
#18 | |
Drives: 2014 BRZ Limited
#19 | |
When you counter this with adding weight in front and up high in the engine bay a turbo, and then the rest of the supporting mods (intercooler, oil cooler, oil catch can, etc) of a turbo system to acheive the same HP or torque you are still are doing the same damage (read "if any") that a LS swap would. So OP, please do it. and then maybe we can all chip in for you to take it CoG tested with the rest of the car completely stock? |
#20 |
Tire Destroyer
Drives: Firestorm+snail
Corvettes are heavier too, COG will change but that doesn't mean it will handle like shit. Example: miatas with ls swaps, there are a ton of track oriented ls miatas that do way quicker laps than a standard one. There are a ton of factors at play, it won't be as balanced but it won't turn the car in to a piece of shit necessarily. Damn this forum is full of hating ass people.
#21 |
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
#22 | |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
What's the going rate for a slightly used FA20 and trans? I get the feeling that's his budget. |
#23 |
ummm, its still a complete list of the correct parts to make sure his swap works reliably, whether or not he buys the stuff from there.......budget build swaps are bad ideas anyways but thats a completely different topic.
#24 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#25 | |
I'd have to imagine the actual complete list of parts alone on this engine swap would be over 100 items. Don't get me wrong, these builds are completely doable and the end result (when starting with a good engine) would be show quality, with very impressive performance numbers. Problem is, as posted earlier, to do this right is about a $70k investment for something so unique that no shop would be able to troubleshoot a problem down the road sometime. It's a great idea for people in the car industry to build to show either the quality of the parts they make, competency of their shop, or as a specialty competition drift vehicle, etc. It's not the sort of build one does when their DD gets into an accident, and they have two spare vehicles to drive (BRZ and TA) that they then take out of commission for a few months in order to do an engine swap on a budget - equal to roughly the value of a used FA20. And not that people won't want an FA20, but with a plethora of EJ blocks out there in both 2.0 and 2.5l sized, with turbos, for cheap - who is looking to spend much more on an FA20 engine? (Not helping that it will likely come without the much needed ECU) As a reference, I once had a V6 model vehicle and wished mine had the V8 option that was available. I spoke to a shop and they flat out said it would be easier and cheaper to just sell my car and find one with the factory V8 than to attempt a swap. The cost of the engine itself was minimal compared to the other costs to get it all to work and the amount of labor involved. I was 17 at the time and the used V8 engines were about $2k. Very naive I was. |
#26 |
I don't mean you have to go to a high end shop to have it done just that the right parts and equipment need to get used. It costs money to play and if you don't do it right the first time it just costs more down the road....cheap, fast, reliable, you only get two and if you want fast and reliable it costs $$$$$ something OP doesn't seem to have........there's nothing budget about your builds...lol
| The Following User Says Thank You to Vides990 For This Useful Post: | OmarGC (09-22-2014) |
#27 |
#28 | ||
Fuck me for asking a legitimate question. |
| Painted front mustache BRZ | AR35 | Cosmetic Modification (Interior/Exterior/Lighting) | 57 | 08-26-2016 04:00 PM |
| BRZ carbon fiber mustache? | Norcalmav23 | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 07-21-2015 03:02 PM |
| Replacing the BRZ mustache | FrSnake | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-06-2014 02:15 AM |
| Mustache | beagoodruslan | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-16-2014 05:05 PM |
| I mustache you a question. | Jive Turkey | BRZ Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-14-2013 10:18 PM |
