86WORX
Old 03-30-2017, 10:07 PM   #337
Prax
Drives: 2017 BRZ Inazuma Edition
Originally Posted by viscositosis.rex View Post
Mobil 1 Extended Performance, and I presume Annual Performance now have reduced levels of calcium and additional magnesium.
Will Amsoil change their formulas to deal with the negative effects of high dose calcium on GDI engines?
Isn't the calcium issue more pertaining to turbocharged or supercharged cars?
Sent from my Nexus 6 using Tapatalk
Prax is offline   Reply With Quote
Old 03-30-2017, 10:44 PM   #338
viscositosis.rex
Drives: Currently 2018 Taco
LSPI (low speed preignition).
It has been discussed.
New tests are coming.
The huge amount of calcium in Amsoil keeps engines sparkling clean.
Will changes be necessary ?
viscositosis.rex is offline   Reply With Quote
Old 04-18-2017, 01:10 AM   #339
skkk
Drives: 2022 BRZ Sport-Tech
Currently using 5W-40.
I feel like the car engine bay smells really bad when I was using 0W-20 if I drive it about 30-45 minutes.
skkk is offline   Reply With Quote
Old 04-18-2017, 02:42 AM   #340
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Seems like as good of reason as any to switch to a non user manual specified oil weight!
Originally Posted by humfrz
I'm old and lazy
Old 07-09-2018, 05:45 PM   #341
E_br4ke
Drives: FRS 6MT
Is anyone running anything different for high mileage cars? Have been running the recommended 0W-20 since 2012.
Getting close to 90,000 mark.
E_br4ke is offline   Reply With Quote
Old 07-09-2018, 07:14 PM   #342
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Spend 20 bucks and get a used oil analysis. 90k is perfect time. It will tell you how the engine is doing and if your OCI is good. Someone else’s car is different and tells you nothing. Running a thicker oil is not always better and will not save an engine long term.
On my 04 WRX I did it at 50k, 100k and next will be 150k in a few years. It’s worth every penny.
Ernest72 is offline   Reply With Quote
