86WORX
Northwest AK, ID, OR, WA
Old 12-20-2016, 04:54 AM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Hey Goodvibes, this thread could become "post your your Sport Line installs"?
Here are some photos of my BRZ on the same setup with spacers:
The Following User Says Thank You to JD001 For This Useful Post:
BAOVAN (12-20-2016)
Old 12-20-2016, 02:58 PM   #16
BAOVAN
Drives: 2015 Crystal White Pearl BRZ
Originally Posted by stockysnail View Post
I've installed/uninstalled many times and the pass through socket set from Harbor Freight with the Allen wrenches with handles does the trick with no risk of hurting/spinning the struts/shocks.
Yes you'll blow the struts/shocks, it's just a matter of when. I'd recommend coilovers from RaceComp Engineering instead of springs. I've had multiple sets of springs and RaceComp's yellow set was the best of all the ones I've tried and ridden in (H&R, Sportline, Pro-Kit, etc).
Thank you sir stockysnail for your input, I really appreciated it. I wish I was able to go with coilovers but they are too expensive for my budget plus the fact that there will be too many variables to deal with (too many adjustments have to be made for the car to handle properly) for a car newbie like me. It is sad to hear that the strut will blow but I hope it won't happen any time soon
BAOVAN is offline   Reply With Quote
Old 12-20-2016, 03:01 PM   #17
BAOVAN
Very nice! How do you like it? Did you use the same technique/method that OP used and have you encountered any difficulties during the installation process? Any clunking or weird noise at all? My apology if I asked too much because I will be installing my Sportline this weekend. Thank you!
Old 12-20-2016, 03:06 PM   #18
gramicci101
Off Topic
It really depends. 1.4" down is approaching the bottom limit on the strut. Some people kill their struts pretty quickly; others last for years with no issues. If you track your car or take it off any sweet jumps, obviously you're putting more wear on the strut and it'll go sooner. Struts are considered wearing parts, so if and when they do eventually go, the Bilstein B6 is an excellent replacement strut that works well with a 1.4" drop. High quality springs and struts will work better than low quality coilovers every time. That can be addressed as it becomes necessary though; there's plenty of time to think about it.
The Following User Says Thank You to gramicci101 For This Useful Post:
BAOVAN (12-20-2016)
Old 12-20-2016, 03:08 PM   #19
JD001
JD001's Avatar
Drives: Subaru BRZ
The springs and spacers were installed by a specialist and included full wheel alignment.
No clunking or weird noises.
Obviously less suspension travel, the ride is firmer but okay.
BAOVAN (12-20-2016)
Old 12-20-2016, 03:14 PM   #20
BAOVAN
Thank you sir gramicci101. I would say I will never track my car. I daily mine to work and off work and the roads here where I live (Utah) are pretty good and even. Speaking of coilovers, I was looking at the cheap and favorable TEIN Flex Z but like I said I decided to go with lowering springs because it is way more affordable and I won't have to deal with those crazy fine adjustments, at least for now. Like you said "High quality springs and struts will work better than low quality coilovers every time" I will definitely consider getting the Bilsein B6 to pair with my Sportlines when the stock struts finally decide to give up on me.
Old 12-20-2016, 03:16 PM   #21
BAOVAN
I see Please update with us once in awhile of how the springs is treating you. Thank you.
Old 12-20-2016, 03:20 PM   #22
gramicci101
Off Topic
Tein Flex Z is one of the outliers. They are not a low quality coilover; they're actually very nice, with a lot of features one finds on more expensive offerings. They cut cost by not being rebuildable, which most other coilovers are. They are effectively a strut, spring, camber plate, and height adjustment package already pre-assembled for you. They'll still last as long as any other strut would, so when it comes time to replace struts, that wouldn't be a bad option to consider.
BAOVAN (12-20-2016)
Old 12-20-2016, 03:46 PM   #23
BAOVAN
You are the man, thank you sir!
Old 01-22-2017, 02:56 PM   #24
ReducingRadius
ReducingRadius's Avatar
Drives: '23 GR86
Nice write-up OP! Looks great too. I'm still torn between Swift springs/OEM struts and Tein Flex Z coils.
ReducingRadius is offline   Reply With Quote
Eibach Sportline Spring review Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2019 07:23 PM
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 11:09 AM
WTB: Eibach sportline lowering spring. bhbnuckle Brakes, Suspension, Chassis 1 03-11-2014 01:05 AM
Cheap used Coilovers VS Eibach Sportline Spring SpeedR Tracking / Autocross / HPDE / Drifting 10 12-25-2013 07:44 AM
