#15 |
Ohh gotcha. When I installed my LCA's I just put on the aftermarket toe arms right away because it was my understanding they were necessary.
-Flickr-
IG @illmattic86 |
#16 |
Drives: Your Car
Wait. Double checking. So is it possible to use PBM LCAs and run only 1.5 - 2 degrees of camber WITHOUT toe arms?
Sent from my HTC One_M8 using Tapatalk
#17 |
Drives: Fr-s
#18 |
Drives: Your Car
But could I reduce camber to 1.5 degrees and not run out of adjustment on the oem toe arms?
I am currently at 2.3 degrees with only coilovers and I plan to reduce it to 1.5. Sent from my HTC One_M8 using Tapatalk
#19 |
Drives: Fr-s
im not sure what you could reduce it to lol, i want to max mine out so i got no info on reducing, but it should be fine.
#20 |
Cpt. Slow
Drives: 2015 series.Blue
Are yo getting any kind of clunking noise from the rears when going over bumps?
I just installed mine and every bump i go over i get the clunking noise. I just went in this morning and torqued everything down but to no avail. |
#21 |
Drives: Whiteout frs
Yeah man I have the same noises. I went crazy re tightening everything, and I was still getting the noise so I called pbm and they said you gotta give the pillow balls time to settle. It defintatly has gotten better over time but anytime I'm on a terribly paved road I get the same noise. It's nothing to worry about.
#22 |
Drives: Raven frs
I know this is an old thread but I maxed out my front ones and there not that low so you have upgrade the front endlinks to go lower ?
#23 |
Drives: '14 BRZ Todoroki/OriginLabo
How low is it? ^
#24 |
Drives: Sapphire Blue ‘23
I just got my pbm pro coils installed today with their rlca and subframe risers and am very impressed by how comfortable it is. I'm lowered an inch and a half all around. My only complaint is that the right rear coil is making a slight sound but only when I go over very bumpy streets or speed bumps.
#25 |
Drives: 2016 FR-S Asphault MT
zombie thread JUST. WONT. DIE.
I have been on PBM Pro coils for about 8 months now. the swift springs are worth the price jump alone. SO SMOOTH. these guys are local to me about 20 minutes up the freeway and I've had their stuff on my AE86 too (the car in the AE86 section is my old car they used to prototype the stuff) and its AMAZING. I refuse to buy anything else. just installed the rear lower arms last weekend, I have the same CLANK noise over bumps. thanks for putting my mind at ease. I was going in and re-tightening everything too. good to know its just the solid joints settling.
#26 | |
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
And yes! solid mounts and pillow balls everywhere make for some tapping noises.. but i'm not complaining |
| The Following User Says Thank You to tato.valverde For This Useful Post: | Shinchu (04-07-2017) |
#27 |
Drives: fr-s
I will attest to everything they make. I have 70k miles on my coils and no issues, no leaks, no nothing. They are a bit stiff for me now that I'm not 24 anymore but I'm getting them re-valved at PBM soon so no issues. Not to sound like a fan boy but Dan and Martin make awesome stuff.
| Tags |
| coilovers, lower control arms, pbm, powered by max, review |
| Voodoo13 Rear Lower Control Arms - Initial Inspection - Install/Review to follow | Travisty75 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 10-23-2016 03:33 PM |
| PA:FS Stance Coilover and Lower control arm (price reduced) | tapsumbongfrs | Brakes, Suspension, Chassis | 11 | 10-13-2014 03:50 PM |
| Powered By max coilovers/lower control arms | keeeefers | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 09-28-2014 12:47 AM |
| Powered by max coilovers/lower control arms | keeeefers | Brakes, Suspension, Chassis | 3 | 08-30-2014 06:52 PM |
| Help with Lower Control Arm install. | DaiTT500 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-08-2014 11:56 AM |
