#113 | |
Drives: 2013 BRZ sprintex SC
Is there anyway just to lower the entire electric power asist level? Like adding resistors on the torque sensors inputs or something like that. Does the loss of eps assist comes from the motor itself or the eps control module input voltage drop because of the wiring to the unit are thin and the high demand causes voltage drop on the unit's power input |
#114 | |
Drives: Frankenstein of parts
Please do not ever do any modifications to the torque sensors, theres countless OEM problems with torque sensor failing and car going full bore to one side. For the loss itself, we are still investigating. We are guessing its either temperature on the mosfets (The oem mosfets appear to massively deteriorate almost linearly with temperature), or its a simple matter of overcurrent protection. We have confirmed that dropping the assist level with my controller does appear to ward off the dreaded cut-out significantly, but not all the way. |
#115 | |
Drives: 13 White MT FR-S
have you tried heatsinks on the mosfets?
#116 | |
Are you sure it isn't issue with the high current inrush that causes the eps ecu input drop in voltage and causes reset? You're made sure there is at least lets say 12v at the ecu input when the protection\cut off\reset kicks in? Will be really glad to try and help you, help us solve this issue. I'm electrical engineer and have access to some pretty cutting edge technology development analog guys and if I'll have more data like schematics, measurements anything maybe we can figure it out together. |
#117 |
The entire back 1.5 inch thick case is the heatsink in this case. We recently found (RedReplicant and a few others who run column modules) that it seems there is indeed a current limit cutoff controlled by the MCU itself. On the prius columns one of our common friends had simply lowered the resistance of a current shunt, and his problems are all gone!
#118 | |
Or you can sell the shunts + schematics\instructions of how to execute the replace and where the shunt ia located. This is really major fault with the car and i just can't understand how anyone with this car do not complain about this. |
#119 | |
| The Following User Says Thank You to Nmstec For This Useful Post: | DocWalt (01-11-2023) |
#120 | |
Thank you thank you thank you. |
#121 |
Amazing guys! Keeping an eye on this.
2013 Series 10 FRS #553
#122 |
#123 |
Drives: None
I have two track days this weekend where I'll be trying a few things, but not the shunt change. Next events after that will be Feb 18/19.
I had my assist fixed to 40% at the last event and it still cut, but it was nowhere near as bad as with the stock controller.
#124 | |
Why not tring the shunt first,seems like this will raise the current limit and prevent the cut off. Do you have pictures of inside the eps ecu? What correctly is the shunt value? |
#125 | |
Drives: None
2. I put the nmstec into the car a few months ago, this shunt stuff was found out about in the last week. Also, I am not entirely sure what kind of fun failures the shunt change could introduce and I am trying to keep the number of changes at a time down so we actually know what made a difference. 3/4. I don't, nmstec may
#126 | |
| rattling when braking | Latiii | Issues | Warranty | Recalls / TSB | 14 | 08-07-2014 01:16 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-21-2013 12:45 AM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 05:52 PM |
| Steering wheel issue | Khalis | Issues | Warranty | Recalls / TSB | 1 | 05-04-2013 02:19 AM |
| Braking Issue In Mid Drift | imravenit | Tracking / Autocross / HPDE / Drifting | 12 | 02-12-2013 04:16 AM |
