Old 09-15-2014, 01:43 AM   #1
LALFAN
Drives: FR-S RS 1.0
Smart Key Question (BRZ Limited Owners)
How does the trunk work, does it have a button above the license plate you push to open or do you still have to take the key fob out of your pocket and push a button on it?
LALFAN is offline   Reply With Quote
Old 09-15-2014, 01:47 AM   #2
shanx
Drives: slowly
you push a button above the license plate. no need to press anything on the key fob.
shanx is offline   Reply With Quote
The Following User Says Thank You to shanx For This Useful Post:
LALFAN (09-15-2014)
Old 09-15-2014, 01:49 AM   #3
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Assuming your valet button in the trunk isn't engaged. In which case you need to use the key inside your fob to open the trunk.
Candlejack is offline   Reply With Quote
Old 09-15-2014, 01:52 AM   #4
LALFAN
Drives: FR-S RS 1.0
Perfect. Thanks guys.
Old 09-15-2014, 12:18 PM   #5
srizzors25
Daedalus Moto
srizzors25's Avatar
I have a question as well about the same thing,
Does the button on the trunk only work for you guys if the key is in close proximity? For me I can only open the trunk if the key is in my pocket or hand etc when going to open the trunk. Say the car is unlocked or even if I leave the key fob in the car the trunk won't open unless I press the button to open the trunk on the dash or grab the key and get it closer to the trunk
Old 09-15-2014, 01:13 PM   #6
cnk
Drives: '13 DGM BRZ Limited
That's how it's supposed to work. RTM as it describes the functionality.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 09-15-2014, 05:45 PM   #7
le14
Drives: 2015 BRZ Series Blue
Quick question, what about the passenger door unlock? I can get into the driver door with my keys in my pocket, but it never unlocks the passenger door also.
Is that normal?
le14 is offline   Reply With Quote
Old 09-15-2014, 05:49 PM   #8
TM
TM's Avatar
Drives: DGM BRZ 6MT
Is that normal?
Normal. You can set it to unlock both doors upon unlocking driver's door. The sequence is in the manual.
TM is offline   Reply With Quote
Old 09-16-2014, 03:31 PM   #9
Candlejack
Candlejack's Avatar
^^^ THIS. One of the first things I tweaked on my BRZ.
My question is, how far away can I drive the car from my key before the car shuts off...or does it even shut off at all? I think it's a weird feature that the car stays on when the key is taken out.
You could get in, start the car, then get out and set the key down someplace...get in your car and drive away, and not be able to start your car back up when you got to your destination and shut it off.
Old 09-16-2014, 03:54 PM   #10
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
I'd imagine there will be a warning notifying you that the key is not present. At least BMW's do this. I've never tested it though, so I could be wrong.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-16-2014, 03:56 PM   #11
aznatama
aznatama's Avatar
Is that normal?
Yes, normal, and it's a security feature I prefer to keep rather than unlocking everything at once. passengers can wait til I push the unlock. If I really want to unlock both doors from a distance, I'll use the keyfob and push unlock twice.
'14 BRZ LTD MT DGM
Old 09-16-2014, 07:46 PM   #12
extrashaky
Drives: 2014 BRZ Limited
If you approach the passenger door and attempt to open it first, it will unlock, and it will also unlock the driver's side.
If you unlock the driver's side first, the passenger side will stay locked. This is to keep you from being carjacked by someone waiting for your doors to unlock so they can jump in from the other side. As has been said, you can turn that feature off so that it unlocks both doors from either side.
It does not shut off. That's a safety feature. If it shut off when it doesn't detect the key fob, it could potentially shut off while you're driving it if your battery went dead or your key fob were defective. That could be an unpleasant surprise.
The car will let you drive without the key until you shut it off. Then it won't restart.
Old 09-16-2014, 07:58 PM   #13
Poodles
Drives: 2015 Series.Blue
Yes you can, but the car will beep at you a bit if it detects you leaving the car with it running.
As to why it does this, if the battery in the key fob dies, you wouldn't be able to drive the car. If it dies you need to hold the fob up to the start button so it can pick up the passive RFID chip in the fob.
Old 09-16-2014, 09:49 PM   #14
Candlejack
Candlejack's Avatar
Makes sense. But it's still definitely strange.
FS: Brand new Smart Key for Subaru BRZ Limited smmmurf Audio/Visual, Electronics, Infotainment, NAV 22 12-03-2017 03:52 PM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Question to high spec smart start owners... WLY AFRICA 6 10-15-2013 12:16 PM
Limited Owners, Best 86 or Best Owners? AznBRZer BRZ First-Gen (2012+) — General Topics 14 08-22-2013 10:04 AM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
