86WORX
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 09-15-2014, 08:48 PM   #15
Createddeleted
Drives: 2014 BRZ - 2004 GLI
I ended up watching the whole drift video XD
Createddeleted is offline   Reply With Quote
Old 09-15-2014, 10:04 PM   #16
Erik1493
Drives: Blue Brz
I have the steering wheel all the way out, and fairly high. My seat is all the way down. When cruising, I sit relaxed to ease my back. When driving spirited I sit closer and more straight up
Erik1493 is offline   Reply With Quote
Old 09-15-2014, 10:57 PM   #17
litemup
Drives: around
Originally Posted by gramicci101 View Post
I'm 6'5". The seat is all the way back and all the way down. The wheel is all the way out and all the way up. The seat is tilted back a little so my head will clear the roof. I can feel the ridge in the roof liner with the back of my head if I stretch a little bit.
^^exactly this. Gotta slouch with a helmet. Has anyone played with extending the steering column AND keeping the stock steering wheel?
I've searched but haven't found the tall-guy solution.
litemup is offline   Reply With Quote
Old 09-15-2014, 11:20 PM   #18
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
- Legs slightly bent when clutch fully depressed (allows brace against dead pedal if needed)
- Steering wheel as close to me as possible and just low enough so that I can still see most of the gauges (more leverage on wheel possible)
- Seat back upright enough so that arm is relaxed and bent while hands at 10 + 2 position and allowing wrists rest at top of steering wheel when straight arm w/o stretching (more support from seat and leverage on wheel)
Tall guy solution... lower aftermarket chair, extended steering wheel column, or custom headliner panel? there's a good ~2" of space above the headliner...
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-16-2014, 09:32 AM   #19
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
thanks for all the good info, i found this thread very helpful. i think i've been too far back and my seat back not reclined enough. the reason i say this is that i am not tall, but it's a very tight squeeze to drive with a helmet on. i'll try your suggestions. i suspect it will make things more comfortable
lionbacker54 is offline   Reply With Quote
Old 09-16-2014, 09:52 AM   #20
aznatama
aznatama's Avatar
Driving with helmet: Flip the headrest around 180 degrees so that it points backwards.
'14 BRZ LTD MT DGM
The Following User Says Thank You to aznatama For This Useful Post:
lionbacker54 (09-16-2014)
Old 09-16-2014, 10:15 AM   #21
DarkSunrise
DarkSunrise's Avatar
Originally Posted by hmong337 View Post
I was given the advice by a professional driver that your leg should still be with a slight bent when the clutch is fully depressed and the bottom of your wrist should be able to sit on top of the steering wheel without having to reach. That's race mode haha.
Cruising around and going to work... ^that but with the seat reclined a bunch of clicks.
5'9 here.
This is exactly how I set my driving position at the track. In my case that means extending the steering wheel all the way out and sitting somewhat vertical.
One thing I love about the FR-S is that the steering wheel itself is fairly vertical compared to most cars, almost perpendicular to the ground. This frees up your bottom hand when you turn the wheel more than 45 degrees. With my GTI, the steering wheel is angled away (top of the wheel towards the front of the car), which locks up that bottom hand on tighter turns at the track. Love the driving position on the FR-S, pretty much perfect.
On the street or for extended drives, I will recline the back about 1-2 clicks from "race mode".
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
hmong337 (09-16-2014)
Old 09-16-2014, 01:57 PM   #22
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
There is vitrually no comparison between an econobox and a sports car. Econobox = sit up higher, sit more hunched forward reaching for the gear lever. Sports car = sit down low, layed back ready position, shifter falls in hand.
hmong337 is offline   Reply With Quote
Old 09-16-2014, 02:08 PM   #23
aznatama
aznatama's Avatar
I wouldn't call it more hunched over, and a sports car is nowhere near "laid back" if you're seated properly. It really all depends on how you personally want to sit and adjust the seat to some extent. The steering wheel angle is taken into account depending on the style of car, but it's usually nothing that can't be adjusted for. Afterall, even semi-trucks are raced, with their huge almost horizontal steering wheels...
'14 BRZ LTD MT DGM
Old 09-16-2014, 02:45 PM   #24
Turbowned
Turbowned's Avatar
I'm 6' 2" and I sit like this guy:
Seatback very close to straight up, not as far back as it can go, steering column telescoped out pretty far (in the BRZ, out all the way), seat as low as it will go and with as much rake as possible.
Old 09-16-2014, 03:05 PM   #25
srizzors25
Daedalus Moto
srizzors25's Avatar
5'6" here, sit pretty close just because I have wee little legs. I like to have the seat fairly upright with my wrists on top of the wheel
Old 09-16-2014, 03:15 PM   #26
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
All the way down and about a click from fully back. Seat reclined, relaxed, knob always in arms reach without having to lean forward. Adjust mirrors properly and don't let anyone move your seat. Make them go through the other side.
Edit: 6'1"
Jesse36m3 is offline   Reply With Quote
Old 09-16-2014, 03:53 PM   #27
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
You'll be surprised how close the driving position is between a Boxster and a Golf GTI once everything is adjusted properly.
krayzie is offline   Reply With Quote
Old 09-16-2014, 04:04 PM   #28
Monkey_Boy
Bleeds WR Blue
Monkey_Boy's Avatar
Drives: '14 BRZ (WRB), '06 Baja (ABP)
Missionary?
Monkey_Boy is offline   Reply With Quote
HID headlight position setting radroach BRZ First-Gen (2012+) -- General Topics 28 01-31-2014 05:21 PM
Whats with the chicks and bro's driving... Pacific Auto Scion FR-S / Toyota 86 GT86 General Forum 65 01-12-2014 04:03 PM
Satnav antenna position notout86 Electronics | Audio | NAV | Infotainment 1 06-14-2013 04:01 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 02:28 PM
whats the best driving sim? Kazama Off-Topic Lounge [WARNING: NO POLITICS] 9 12-24-2011 08:04 PM
