86WORX
Old 12-30-2014, 12:02 AM   #71
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Mother of God!
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 12-30-2014, 07:53 AM   #72
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Awesome!! Do you use 5th gear because it's the strongest driveline?
(For those that aren't familiar with this transmission, the 5th gear is a direct drive straight off the crank, through the input and output shafts into the prop shaft).
I guess you're not going to tell anyone how you ensure those rocker pins stay in?
Nigelr32 is offline   Reply With Quote
Old 12-30-2014, 10:42 AM   #73
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Yeah given I broke 4th gear with less power under racing conditions I decided that 5th would be safer as it should be a little stronger. This dyno reads about 10% low also (baseline oem was 153 whp).
Element Tuning is offline   Reply With Quote
Old 12-31-2014, 10:48 AM   #74
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
So where on the East Coast are we going to be able to see this thing on a track this coming year? Will you be posting a schedule?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 01-02-2015, 09:15 PM   #75
Element Tuning
We haven't made an announcement but we picked up a corporate sponsor and wI'll bring the FRS to the next level where we'll race against some of the fastest TT1 and TTU Vipers, Z06s, and GTRS in the Whelen USTT Championship and also a round or few of Global Time Attack. So places like Watkins Glen, Road Atlanta, VIR, NJ Motorsports, Pittsburgh International, and maybe NOLA and Ohio.
The car is still so much lighter than the competition which worries me a little since these classes are "power to weight" ratio based.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
civicdrivr (01-05-2015), DarkSunrise (08-31-2015)
Old 08-31-2015, 09:49 PM   #76
Raceseng
Raceseng's Avatar
Phil - Is there enough piston to valve clearance for a ratio rocker arm?
Raceseng is offline   Reply With Quote
Old 08-31-2015, 10:36 PM   #77
celek
Resident Gear Head
celek's Avatar
Jarrett, if you are thinking what I am hook it up.
celek is offline   Reply With Quote
Old 08-31-2015, 10:49 PM   #78
Raceseng
Raceseng's Avatar
We visited Moto East today to look at the heads, rocker arms... etc. There is a TON of development in doing a set of ratio rocker arms but we have a lot of experience under our belt.
The Following 4 Users Say Thank You to Raceseng For This Useful Post:
celek (08-31-2015), DustinS (12-03-2015), FrX (09-01-2015), Jonsey (08-31-2015), Lonewolf (09-01-2015)
Old 08-31-2015, 11:16 PM   #79
celek
Resident Gear Head
celek's Avatar
I will have to check my specs on the Pistons I had made I think I allotted 2mm more lift than stock
Old 11-26-2015, 09:12 PM   #80
sam69
Drives: GT 86
Uh look at the manufacturing inconsistency here! These are the two new rockers I purchased to be modified and tested.
I can see why one could fail more easily than another given how the secure the ends without uniformity! It's a roll of the dice really!
Hi Phil any updates on how your modded rockers are holding up as looking at some of mine they look like the top rocker
Could I send you my rockers to be modded and what is the cost involved ?
Regards sam
sam69 is offline   Reply With Quote
Old 12-03-2015, 03:41 AM   #81
sam69
Drives: GT 86
Bump
Old 12-04-2015, 07:56 AM   #82
smudge
Drives: Supercharged GT86
I don't suppose you want to let us all know how you stop the pins coming out Phil?
I'm thinking a spot welded tab, connected to the rocker at the outer ends so as not to affect the strength of the main stressed parts of the pressed steel?
Originally Posted by 350matt View Post
wasn't there a thread a while ago about using an lexus ISF follower? these had a bigger roller and pivot pin retainer
don't know if they drop right in though, bound to need some mods though
Was there any update on this from Element Tuning?
smudge is offline   Reply With Quote
Old 12-04-2015, 04:00 PM   #83
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Follow Element Tuning's page on Facebook. Phil is pretty responsive on there. Element Tuning built my motor and its running fine with up to 22 psi of boost.
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
The Following User Says Thank You to Darryljr11 For This Useful Post:
smudge (12-05-2015)
Dented rocker panel daftpunk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 49 08-15-2017 11:41 PM
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 11:42 AM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 08:47 PM
Right quarter and rocker - Ottawa Mgb_bj70 Exterior Parts (Aero, Lighting, Etc.) 0 01-01-2014 04:23 PM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 01:03 PM
