#57 | |
Drives: Hydra EMS Powered FRS Raven Black
We talked about making a tool that would allow us to compress the spring while the heads were in the car and the cam in place so I guess he made the tool. Luckily the shim we had originally used had the correct valve lash with the new rocker.Not something I would recommend unless you got as lucky as I did. Normally the engine would need to be taking down but after cutting the oil filter apart with no debris (bearing or other), perfect leak down results, and we accounted for the shim, rocker, and pin I felt it was worth it to "get her done" and go racing this weekend. There is still a little risk but I've decided I'm ok with it for my personal car since I really want to continue long term abuse/durability testing of Elment Tuning motors. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | Calum (09-16-2014) |
#58 |
Modified a rocker to test so the pin cannot walk out again and got the motor back into the FRS last night. She's ripping to 9k rpm again! Those Perrin pulleys sure do look sweet next to my corroded stock ones. LOL!
![]() A couple more things to iron out and hopefully we'll be on the road to Limerock tomorrow. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | sw20kosh (09-17-2014) |
#59 |
Off Topic
What do you think the possibility is of our rockers being the same dimension as existing rockers for another vehicle? I wonder if there are already aftermarket options out there that fit and we just don't know about it yet. If there are, that seems like an easy way to have stronger rockers with more precise measurements.
#60 | |
![]() Quote:
#61 |
Junior
Drives: a car
This is why im getting my engine eventually built by @Element Tuning. Nice job Phil.
Also kinda wanting to work for Element Tuning now
#62 | |
That Guy
Drives: 2013 asphalt FRS MT
Now that you mention it, I have a fleeting memory of someone saying there is some similar parts between the top end of the FA and another toyota motor. You might try looking through Homemade WRX a.k.a 3MI Racing's old posts or maybe even argx7's posts. |
#63 |
I remember reading here about someone saying they saw crank and bearing failures on engines with lightened parts on both front and rear ends.
Maybe something to do with harmonics? They seemed to indicate they'd seen more failures on engines with both lightened pulleys And lightened flywheels. Maybe since you're wanging your engines out to 9K you might be out of the harmonic range? I'll know in a couple months if I'll have enough to get the built engine from Element Tuning. |
#64 | |
![]() In all seriousness I do think with inline motors with long cranks I can see making a case that a heavy damper could help if the motor isn't balanced well. With that said this fine girl's Element Tuning engine got us through the weekend with flying colors. She was absolutely screaming around the track! ![]() Here are the 25 seconds of Lime Rock Park that make you want to go back!!! We just missed out on first place at the Trans AM and Whelen USTT Championship in TT1 to a race prepped GT Viper by 4/100ths of a second. Given that has been a winning car and we are no where near TT1 spec (we just decided to up class the car and even the TT3 winner was faster on the straights. LOL!) I'm happy with the result and the testing we got out of the weekend. I think I'll discuss more about the oiling and the engine in the other bearing and oiling thread as it's most relevant over there. Thanks, Phil Grabow |
| The Following User Says Thank You to Element Tuning For This Useful Post: | SportInjected (09-25-2014) |
#65 |
Drives: '14 GT86 project, '13 GT86 DD
I don't suppose you want to let us all know how you stop the pins coming out Phil?
I'm thinking a spot welded tab, connected to the rocker at the outer ends so as not to affect the strength of the main stressed parts of the pressed steel?
#66 | |
Drives: toyota mr2/ Toyota GT86
don't know if they drop right in though, bound to need some mods though |
#67 |
Drives: waiting on a 2021...
This thread (and the few like it)are why I keep coming back to this forum and wading through all of the "my air filter on a piece of muffler pipe is better than your air filter on a piece of muffler pipe " threads... Actual useful information.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| The Following 4 Users Say Thank You to zooki For This Useful Post: |
#68 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
Hey all this talk off muff and pipe is getting me excited.
#69 | |
| The Following User Says Thank You to Element Tuning For This Useful Post: | Ultramaroon (12-30-2014) |
#70 |
9k RPM on the dyno and still hanging on. Oil pressure is good too
![]() http://instagram.com/p/xNjK8Bx_hH/ |
| The Following 5 Users Say Thank You to Element Tuning For This Useful Post: | BatStig (12-30-2014), Griever423 (08-31-2015), Koa (12-30-2014), Ultramaroon (12-30-2014), whataboutbob (12-30-2014) |
| Dented rocker panel | daftpunk | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 49 | 08-15-2017 11:41 PM |
| Auto launch blows! | feldy | Engine, Exhaust, Transmission | 83 | 04-14-2017 11:42 AM |
| Rusty Rocker | Nassty | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-01-2014 08:47 PM |
| Right quarter and rocker - Ottawa | Mgb_bj70 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-01-2014 04:23 PM |
| This blows... | finch1750 | Electronics | Audio | NAV | Infotainment | 19 | 06-21-2012 01:03 PM |
