#29 |
I meant I assumed it was upgraded from stock, was curious on how much additional spring pressure was on rockers and if that combined with higher rpm is going to accelerate deflection, failure or rollers walking. You had rockers walk on stock springs? Were you runing over 7500rpm?
#30 | |
Boosted
Drives: Not a supra....yet
Oh elements car has upgraded springs, but in our case they were stock Sent from my iPhone using Tapatalk
#31 |
I changed my post, were you running over 7500rpm on high boost when your rockers walked?
#32 |
Drives: Hydra EMS Powered FRS Raven Black
Well unfortunately we have 18 other engine builds and are under a timeline to deliver Factor Five their dry sumped race engine so my car has been kicked to the curb. LOL!
I'm rarely lucky so I'm going to say one intake valve is tweaked but until we leak it down we wont know. I may get to it after hours in the next few days but we'll see. |
#33 | |
Boosted
This car is on pump, 12psi and 7800 Sent from my iPhone using Tapatalk
#34 |
Because compromise ®
Drives: Red Herring
So Subaru and Toyota will be doing a recall?
#35 |
Also lets keep in mind my failure is not a result of spitting the rocker out intact. This failure is either a less than ideal rocker pin installation at the factory or its a result of being used in a higher stressed application than designed for.
In my case I am not a fan of excessively high valve spring seat pressures so we do run only what we need. This does cut down on valvetrain stress and wear. Only in cases where really high ramp rate cams would warrant a high seat pressure spring but you would still have all of the downsides. I would suspect this is part of the reason Element Tuning motors don't have excessive valve bucket wear like so many other engines we see posted with bucket wear. With that said we are still probably double the oem for boosted applications in the 60 psi range. So we are exerting more force against the rocker roller and we are also spinning it much faster. So I would think more pressure and more rpm exerted against the roller as it follows the cams basically spun the pin (axle) and eventually it walked out. While this may be an isolated incident, I say there is no such thing on an application that is 3-4 times factory HP. We will secure the pins on every engine we build as it's always best to accommodate for a potentially inadequate part. It would be zero consolidation for a client to save $200 only to end up with a paper weight after a $20 rocker fails. Last edited by Element Tuning; 09-10-2014 at 01:38 PM. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | GT86_PRAGUE (12-05-2014) |
#36 |
Drives: 2014 FR-S 6MT Whiteout
Hey I just realized you guys are in Maryland. I think we need to have an open house for FT86Club at your place.
#37 |
Boosted
No they wont, these motors weren't made for boost and the majority of the motors i know blowing were fi Sent from my iPhone using Tapatalk
#38 | |
![]() Maybe one day when I'm not pissed at my FRS. I think I need a few more trophies and I'll get over it. LOL! |
#39 |
#40 | |
Boosted
Yup, funny that the car was barely on any load when it happened. The car is now being shipped overseas though and is getting a 2j or lsx. While the one that is still in the states I'm going to give the fa20 another shot Sent from my iPhone using Tapatalk
#41 |
Drives: 2013 Black FR-S
So he floated a valve and caused damage to his engine at 12 psi on pump gas running 300-330 wp? All these damaged motors is making me think this engine isn't as strong as people initially thought.
#42 | |
Boosted
Its not sadly Sent from my iPhone using Tapatalk
| Dented rocker panel | daftpunk | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 49 | 08-15-2017 11:41 PM |
| Auto launch blows! | feldy | Engine, Exhaust, Transmission | 83 | 04-14-2017 11:42 AM |
| Rusty Rocker | Nassty | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-01-2014 08:47 PM |
| Right quarter and rocker - Ottawa | Mgb_bj70 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-01-2014 04:23 PM |
| This blows... | finch1750 | Electronics | Audio | NAV | Infotainment | 19 | 06-21-2012 01:03 PM |
