Old 09-08-2014, 10:49 PM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by evo4g63 View Post
I have a lightly used Full blown radiator w/ fan shroud assy(150 mile) for sale. I had it on my JDL kit. PM me if interested.
Pmed
2013 Series 10 FRS #553
Old 09-09-2014, 12:43 AM   #16
sw20kosh
Drives: 2013 Black FR-S
Fullblown just PM'd me right now to tell me that their shroud now fits the stocker. Just specify that you have a stock rad.
There is no evidence thus far that a fullblown or koyo rad works better than stock rad on the track without significant airflow modifications to the frontal area and engine bay. They may work better with more airflow through the frontal area but the problem is just that, airflow.
During a recent track test on turbocharged setups almost exactly the same (only difference was one was on e85 at 330 whp and one was on 100 octane 280whp) and running the same lap times around the track, a koyo and stock rad were tested in 110 deg ambient temps. Both overheated just as fast. 2-3 hot laps was enough.
I wouldn't worry about getting a thicker rad right now. Most people think that it will automatically be better because it is bigger. It wont. You need airflow to make those thicker rads work better. Airflow mods like removing stock bumper beam, properly louvered vented hood, possibly massive spal fans and ducted frontal area.
Old 09-09-2014, 12:48 AM   #17
jflogerzi
jflogerzi's Avatar
I have been following your thread so you think this more important to have the following:
Stock rad+shroud to use spal fans and a bigger oil cooler? When you said you overheated, you mean oil temps?
Old 09-09-2014, 12:52 AM   #18
sw20kosh
Both coolant and oil.
We had to back off when seeing 230 F coolant and 260 F oil. My tuner also has a failsafe that puts me on wastegate spring pressure (6psi) when coolant gets to 230 F and oil to 260 F.
Are you planning to run this car on the road course or drive spritedly in the heat in say mountain twisties. If you are not, temps become much much less of a concern. You wont be overheating by doing a few wot pulls on the highway every once in a while.
Old 09-09-2014, 12:55 AM   #19
jflogerzi
jflogerzi's Avatar
Are you planning to run this car on the road course. If you are not, temps become much much less of a concern.
Yes but I would say its going to be lightly tracked. Maybe 4-5 events a year. I would love to speak to you outside of this forum. Gtalk or text msging?
Events would be SoW and these size tracks. Also I would not be able to push the car nearly like Mike @ CSG or other seasoned drivers.
Search this Thread:
Advanced Search
Spal Fan Shroud & Koyo Radiator Carolina Dyno Forced Induction 64 12-14-2016 09:38 PM
FBM Aluminum Radiator Shroud Release FullBlown Engine, Exhaust, Transmission 7 09-28-2014 06:01 PM
radiator support shroud? WhiteFRS69 Cosmetic Modification (Interior/Exterior/Lighting) 4 07-18-2014 08:51 PM
Full Blown Stage 2, Rad + Shroud + SPAL install Ironsquid Forced Induction 3 02-11-2014 11:47 PM
FBM Aluminum Radiator Shroud Release FullBlown Engine, Exhaust, Bolt-Ons 0 01-22-2014 07:29 PM
