#29 |
Drives: 2014 WRB BRZ Limited
This might be a stupid question, but for those of us running a 2.x beta rom, any reason to update?
#30 | |
Shiv,s 2x tunes are much better knock wise and i pulled a bit of timing in problem areas for 98 ron fuels so the amount of fbkc or flkc will b verry little hopefully
#31 |
Drives: Scion Fr-s
During the beta I keep getting code p2096, due to my after market header. Is that code now disabled? Tired of always plugging in my OFT and clearing it.
#32 |
Drives: 2013 BRZ Limited WRB
Wait, is this true? I deleted one of the 1.x 93 tunes and replaced it with a 2.x 91 tune (and renamed it so it'd be obvious). But everything else was 1.x. If it didn't flash a 2.x, then what the heck am I currently running?
#33 | |
The code your getting is P2096 post catalyst fuel trim system too lean . You may have exhaust leak did you use new gaskets when headers installed. Are you running stock intake as you may get this code if fuel trims are high due maf scaling off. could also be leak in intake after maf sensor or maf sensor gasket. |
#34 | |
,as we say over here.I'm talking about .bin format (editable full format tunes) tunes and .dev database format non-editable tunes. Not tune revisions like 1.5x or 2xx ect you can mix those no problem. but oft will only hold either all .dev format or all full format .bin tunes at any one time. |
| The Following User Says Thank You to steve99 For This Useful Post: | nocturne1 (09-05-2014) |
#35 | |
Drives: Scion Fr-s
#36 |
Drives: SWP BRZ
@Shiv@Openflash,
do we need to re-upload non-beta map if we already have beta? |
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | 355rockit (09-05-2014) |
#37 | |
| The Following 3 Users Say Thank You to steve99 For This Useful Post: |
#38 | |
Drives: Scion Fr-s
http://www.datazap.me/u/juanito08/206log?log=0&data=1 |
#39 | |
Your AFR look fine and appears to be folowing the Open loop fuel tables well P2096 is a lean condition and that log is not showing it but it could be an intermittent exhaust or, intake leak near maf sensor or downstream of maf sensor . check that as well as exhaust flanges near O2 sensors The AFR is based of the readings of the front 02 sensor, but its likely the rear O2 sensor that causes code p0420 and p2096 or the difference in readings of the front and rear 02 sensors. As you have an OFT you can monitor the rear O2 sensor as well by selecting WIDEBAND AFR log parameter the scaling might be a bit off as your supposed to install an aftermarket sensor., but for the purpose of checking the rear 02 sensor it should work. I just tried it on my car and the front and rear reading move in sync once the sensors are warmed up do another log and log Wideband Afr afr afr commanded ltft maf v rpm engine speed throttle fuel pressure the afr , wideband afr and commanded afr should all follow each other. The second 02 sensor appears to take a couple of minutes to heat up and produce a reliable signal. If you definitly dont have any intake or exhaust leaks its possible the rear o2 sensor may be damaged or not working properly or cross threaded loose cable not plugged in correctly ect. is the p2096 code permanent can it be cleared ? |
#40 |
Drives: '18 STi
So we're going to be getting v2.06 maps on Monday- sweet! I just have one minor and probably redundant question but, will there be much of a difference from the v2.03 and the v2.06? Please excuse my ignorance, as I haven't caught up to recent updates since the release of the v2.03 maps. Even with that said, I'll probably still load my car up with the v2.06 map and boot out the v2.03 map that I'm currently running, just to be safe and updated.
#41 |
Drives: MR Spyder/GT86
So to be sure this flash works on the Euro cars right?
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 10:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 09:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 01:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 04:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 10:02 PM |
