#295 |
Drives: 2014 Subaru BRZ
Almost thought something was wrong with mine. Good to know its just normal.
#296 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I have another really dumb question, how much knock correction (KC) is acceptable? I updated the tune and ran up and down the road and saw it go anywhere from 2* to 5*. I don't have the light to do a safe datalog tonight, but I'll run one from 2.5k to redline and one cruising and upload them tomorrow after work.
Basically I just want to know if its safe to drive it to and from work tomorrow, or if I should flash back to stock. Thanks! |
#297 | |
For knock you need to log FBKC Feedback Knock control on an OFT this is (Knock Correction) easily confused with KC Learned or KCA, and FLKC Fine learning Knock Control and IAM ignition advance mutliplers. Have a read og the knock corection thread below. Look for IAM = 1 ideally or very close to 1 FLKC and Knock Correction(FBKC) to idealy be zero but the occasional 0.7 or so is acceptable Values like -2 or more are a concern If you getting -5 Knock correction that is not good but I suspect your logging KC Learned |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Bobblehead (10-06-2014), zc06_kisstherain (10-06-2014) |
#298 |
Drives: 2014 WRB Bravo Romeo Zulu
In terms of reliability, is it safer to run 91 vs 93 stage 1? Or is it equal?
Currently running 91 tune but still fill up with chevron 94. Shell 91 feels a bit sluggish in comparison, probably due to a timing retard... Which stage 1 tune do you guys prefer better and why? |
#299 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Bobblehead (10-06-2014) |
#300 | |
Drives: GT86
#301 |
I made a cruising datalog, I'll upload it when I can, but couldn't do a safe 3rd gear pull due to the rain.
My Advance Multiplier stayed mainly at 1. I saw it go to .96, .99, and saw it at 0 in city traffic. I closed and re-opened the realtime data and it was back up at 1. My AFR while cruising at 55mph and 10% throttle was ~14.58 to ~14.74 or so. Under a heavy pull up a hill it got down to around ~12. Do these numbers check out? |
#302 | |
Try changing brands of fuel some are way better than other even with same octane rating |
| The Following User Says Thank You to steve99 For This Useful Post: | Bobblehead (10-06-2014) |
#303 |
OK thanks! Right now I'm on a mixed tank of Kwik fill and Sunoco 93's. I'll run this tank down and test which one is better.
#304 |
Drives: 2013 FRS
OFT OTS v2.062 is now available for download. The only change (as documented the change log) is added support for ZA1JD00D calibration ID. No mapping changes otherwise. So unless you have a ZA1JD00D ROM and are waiting for tune file support, there is no need to download this latest release
![]() Cheers, Shiv |
| The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post: | CamryDS (10-07-2014), chas3wba0 (10-07-2014), flippy (10-07-2014), papatango1976 (10-07-2014), tmichel (10-07-2014) |
#305 |
Drives: Toyota 86 GTS
I'm curious why Stg1 91/93 have -14.88 base timing for the soft rev limiter and Stg2 91/93/E85 all have -0.14.
Does this mean Stg2 has a softer limiter and would Stg1 7600rpm be better at -0.14 instead? I accidentally put the -14.88 from Stg1 in my Stg2 maps and the limiter still threw me forward in the seat. Thanks |
#306 | |
did you check the RPM fuel cut setting ? think its under misc limits folder they need changing as well think it 7600 cut and 7450 resume but check the table in a A01G OFT rom |
#307 | |
US and EU Stg1 and Stg2 soft limits are consistent across the board. Stg1 = -14.88, Stg2 = -0.12. |
#308 |
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 10:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 09:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 01:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 04:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 10:02 PM |
