#281 |
Drives: 2013 FRS
Nope. The tune is still there. All you did was effectively reset learning so expect your idle to a bit a little more lumpy until it re-learns. Same with throttle response (initial dead spot) until it re-learns too.
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | smellslikecurry (09-25-2014) |
#282 |
Drives: Sonic Blue 2014 GT86
Forgive my ignorance but is there an E85 tune to run on a stock car G series can't seem to find it in either 1.59 or 2.06 ??
#283 |
Drives: 2013 FRS
#284 |
Drives: Toyota 86 GTS
Shiv, I think this proves how little doco the OFT has. The first night I had mine I tried upgrading the dev file, with generated tunes still on the tablet. Then I was up until 3am trying to fix it. I blew one of my erases in the process because I was trying everything. Finally uninstalling openflash manager fixed it. Even if there was just a wiki we could maintain it would be better than than answering the same questions over and over because the answers only exist in 6 month old threads, for previous versions.
| The Following User Says Thank You to Wayno For This Useful Post: | chas3wba0 (09-25-2014) |
#285 |
Seņor Member
They are there and you will love them. Check steve99's thread on it. You use the Stg2 EL 85 map.
1974 TA22 Celica
2013 86 GT |
#286 | |
Drives: 2013 FRS
#287 |
Thanks guys wasn't sure if the EL 85 was the right one . I appreciate all the info on here but some of it just goes way over my head . PS wayno took me many hours to work out how to add a tune as well.
Still get lost in how Rom Raider works (which is probably a good thing could do some real damage there).
#288 | |
OFT Tips http://www.ft86club.com/forums/showthread.php?t=71157 when you have that sorted E85 on stock car http://www.ft86club.com/forums/showthread.php?t=67310 read here http://www.ft86club.com/forums/showthread.php?t=74754 then the rest of the links below you should be sorted by then
| The Following User Says Thank You to steve99 For This Useful Post: | tmichel (09-25-2014) |
#289 | |
Drives: WRB BRZ Series.Blue
The values will start going up as I put more load, and the values stay consistent. Please note that this OFT was converted from being registered to a N54 platform. I have the OFT cleared, with the FT86 upgrade template, and fully up to date. |
#290 |
Drives: 1980 corvette, 2014 Subaru BRZ
I cant seem to find anything about this, either i suck at searching or I am just over thinking things.
It was mentioned that we NEED to use the new XML files for the 2.x maps to work but i did not see any way to specify designate them to be used? Does the program just know to look beside the tune folder for the XML or is there a step that I am missing to update my 1.x tune to 2.x tune
#291 | |
Drives: '13 DGM BRZ Limited
| The Following User Says Thank You to cnk For This Useful Post: | G-Man (09-29-2014) |
#292 |
Can someone please check mine??
![]() OTS 2.06 stage 1 93 oct http://www.datazap.me/u/fa20frs/ots-...2&zoom=880-998 Thanks~ |
#293 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Hey guys! I got mine yesterday. The first thing I did was plug it in to OFM and let it do its thing. (I assume it was updating).
After that I flashed the Stage 1 tune onto my car. It feels great, but at 3900 to about 4400 RPM I get a ticking noise. Is this normal? I remember another user had this on his supercharged FRS, but it was a Perrin tune, IIRC. Other than the AVC tick, the car feels brand new and incredible. Should I have updated the tablet after I read my car's tune? |
#294 | |
you will need to download and apply the new template file via opeen flash manager software or you logging will not work instruction on open flash download page |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Bobblehead (10-04-2014), veck (10-05-2014) |
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 10:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 09:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 01:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 04:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 10:02 PM |
