86WORX
Old 09-23-2014, 12:53 AM   #253
s0sl0w
Proud of Boxer
So can this get rid of cels when running catless headers?
s0sl0w is offline   Reply With Quote
Old 09-23-2014, 01:03 AM   #254
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Yes
Old 09-23-2014, 01:38 AM   #255
aristo
aristo's Avatar
Drives: BRZ SWP 14
OFT v2.06 Non-Beta
Originally Posted by B-R-Z View Post
Yes
Mind if I ask why you run the 91 tune on 93 gas?
Nvm just read your post above sorry
Thanks
aristo is offline   Reply With Quote
Old 09-23-2014, 02:19 AM   #256
chas3wba0
chas3wba0's Avatar
Drives: Yes
http://www.datazap.me/u/chas3wba0/st...0&data=1-11-12
Out of curiosity, I ran Stage 2 (v2.06) for a week with the FT86SpeedFactory catted UEL header and then took a quick log. I'm back on Stage 1 now, as recommended by Shiv, but I know some are curious about whether Stage 2 works well with this header.
Everything looks decent to me (someone please confirm this), but no obvious gains over Stage 1. Will do another log on Stage 1 (v2.06) sometime this week, for good measure.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
Wayno (09-23-2014)
Old 09-23-2014, 05:57 AM   #257
rcampici
Drives: GTS86
Not sure if this is the right thread.
But have a problem with OFT OTS v2.061 Stg2 EL A01I
I have a fault code P0420
I thought this was turned off, I also note that Rom Raider Trouble Codes does not list this code.
I am new at this and a steep learning curve for me so I will appreciate any help
rcampici is offline   Reply With Quote
Old 09-23-2014, 06:22 AM   #258
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
No it's not turned off, we have the modified files in the group, still waiting for approval.
Old 09-23-2014, 06:23 AM   #259
steve99
Yes its missing out of the OFT Romraider definitions for its been fixed by the romraider guys but not yet filtered across to the OFT definitions.
Email shiv and he will sort it.
if you cannot wait use def below A01I is not a calid modified rom so standard RR def will work this is NOT always the case.
Old 09-23-2014, 06:27 AM   #260
Wayno
Wayno's Avatar
https://www.dropbox.com/s/4lwmcplvg3...09-12.zip?dl=0
The Following User Says Thank You to Wayno For This Useful Post:
steve99 (09-23-2014)
Old 09-23-2014, 07:50 AM   #261
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Thanks guys, I'm just paranoid about the effects this might have, especially with my warranty.
Has anyone had warranty work refused (DI seals, crickets) because of an OFT tune?
Bobblehead is offline   Reply With Quote
Old 09-23-2014, 08:05 AM   #262
steve99
Just Flash back stock ROM (tune)
If you have headers they usually spot those, as well as turbo's and superchargers.
Bobblehead (09-23-2014)
Old 09-23-2014, 08:47 AM   #263
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Is there a way to lower the revs on a cold start? As much as I like the relatively loud start (with my Perrin exhaust), I wake up my toddler at 7:00am. Otherwise I'm going to have to start parking a couple of blocks away...
Thanks.
milhouse is offline   Reply With Quote
Old 09-23-2014, 08:57 AM   #264
rcampici
Drives: GTS86
Originally Posted by Wayno View Post
Thanks Wayne and Steve.
Wayne on the files you linked to, the defenition file has the code for 0420, the question I have is this, can that defenition file be used on the latest 6.01 release...
Old 09-23-2014, 09:01 AM   #265
Wayno
Wayno's Avatar
You mean 2.06? Yes
Old 09-23-2014, 09:32 AM   #266
rcampici
Drives: GTS86
You mean 2.06? Yes
Yes . sorry mate
I have assumed it is compatible and did changes to official release, reason that I am not sure about the 98 and 100 situation.
The latest 2.061 worked well but for the very occasional p0420 code.
I am for a long drive to Sydney in the morning some 600K from here, I will get to test it properly.
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
